Question about Chime Home
I have a Daniel Dakota quartz mantle clock with Westminster chime but a black wire coming from chime housing and going in battery compartment came loose and it stopped chiming. I'm sure it's a simple fix or I'm hoping so because I love the chime feature.
Posted by patricia smithhandy on
chrisheman
    Novelist:
  • 145 Answers
It is the negative wire from the battery box that came loose. Need to solder it back onto the battery box negative attachment point. Have a good look at the battery box outer side where the previous soldering point should be visible and solder it back on at that point.
Posted on Nov 07, 2017
1 Related Answer
Anonymous
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
Daniel Dakota Westminister Chime clock not keeping time. The pendulum moves but the hands do not. Any idea what is wrong? Thanks! Donna Hartman
Hello, Donna -
I found and looked through the owner's manual for the Daniel Dakota Westminster Chime clock:
https://secure.img1-fg.wfcdn.com/docresources/23391/13/139903.pdf
If you have not already done so, you may wish to insert fresh AA alkaline batteries in the clock. (Page 4, Image 9 of the owner's manual in PDF format) Follow those directions.
Then, look on Page 5 [Image 7, PDF document] regarding setting the time.
Step #8 states:
Never turn clock hands counter clockwise as it will interrupt the chime sequence and damage the clock.
Did you or do you know if someone else reset the time on the clock by moving the clock hands counter clockwise? If so, that is the cause of your problem.
A local clock repair shop may be able to fix your clock, or tell you if it is worth repairing.
Jan 05, 2018 | Chime Home
Clock is ticking but not chiming
Have you ensured that the strike train is wound?
UsedClockParts.com
Nov 21, 2016 | Home
I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Jun 23, 2010 | Watches
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
HOPE THIS HELPS.
Sep 23, 2009 | Elgin Watches
Home Logo
217 people viewed this question
Top Chime Home Experts
Marvin
Marvin
Vernon Taylor
Fahr Quad
Are you a Chime Home Expert? Answer questions, earn points and help others
