Why wont the turntable turn and play, I tried to ground it but the whole unit is plastic. Any suggestions?
SOURCE: GE Spacemaker XL 1400
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
SOURCE: Door won't open and turntable does not turn
unfortunately you may have to reset the unit. This will cause you to lose everything saved in memory so make sure its not just a DVD stuck in the mechanism. To reset to factory default turn unit off then press and hold Stop and press Standby/On
SOURCE: Sony Stereo turntable system PS-X55 Power failure
i used to own one of these? had it for 28 years and it was brilliant but temperamental during use. it sounds like your direct drive motor has given up the ghost ............so to speak? its unlikely you will be able to purchase a replacement due to its age? if you in the market for a classic retro quality replacement try this company?
http://www.retrohifi.co.uk/
SOURCE: Aiwa AP-2600 Direct Drive Turntable - platter not rotating
if the platter is removable by you and easily, might need just a little cleaning and lube at the center . the platter is the top rotating plate that you were pushing to get started.simply pulls out around a center key. check with local service shops how much they would charge for this kind of cleaning and lubing. $25.00 might be a good price to allow a decision, whether to buy a new.
SOURCE: Trying to find a way to get the turntable of a
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
