Question about Dual Car Audio & Video
SOURCE: adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Posted on Apr 09, 2008
SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
Posted on Jun 17, 2008
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
SOURCE: best wiring hook-up from car amplifier to sub-woofers
Try this wire diagram for speaker connection
Posted on Apr 14, 2010
Feb 17, 2013 | Car Audio & Video
Oct 06, 2008 | Yamaha RX-V659 Receiver
Mar 11, 2011 | Car Audio & Video
Mar 09, 2011 | Dual Electronics XD1222 Car USB Player
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
Feb 07, 2011 | Car Audio & Video
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Nov 24, 2006 | Q-Logic QLT-.3508SS Car Subwoofer
334 people viewed this question
