Televison & Video Logo
Question about Curtis Televison & Video
I have a LCD2425A Curtis flat screen tv. I just want to hook a digital antenna to it and get channels. the problem when I try to go to the channel source the lock section won't let me get there.
Posted by Bob Zoller on
5 Related Answers
Telecom
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
Anonymous
  • 1139 Answers
SOURCE: No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Posted on Nov 03, 2008
Anonymous
SOURCE: HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Posted on Nov 24, 2008
Anonymous
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
Anonymous
  • 105 Answers
SOURCE: Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Posted on Jun 24, 2009
Just bought a !9" digital flat screen Apex. Hooked it to an indoor HDTV antenna. All I can get is "NO SIGNAL". What do I try next?? Bob E, Technical Dunce over 80.
Bob, If you have an hd ready tv, and hooked up the Ant. then the next thing you should do is go to your menu and select the tv feature and then scan for channels. This should program the channels for you. Most TV setups are like this. You should have a option for cable or antenna/tv input. select Antenna. You r should be good to go once the channel scan is done.
Hope that helps
Dan
1helpful
No picture but have sound
Check the cable connections that you have. Try a different channel or make sure that its on the right input or source. Make sure cables are firmly connected. Try to switch it to ATV mode.
Unlock Curtis lcd2425a
got the original remote? GOT a box or not?
MY CHANNELS DO NOT APPEAR WHEN I USE AUTO SCANN ON A CURTIS TV MODEL LCD2425A
Try to direct enter a channel with the number buttons on the remote--if that works you can then in the menu "ADD" it to the set's memory--time consuming but may work.
If no luck let me know: using box? Connected to coax fitting? Rear audio and video jacks are working?
I have a curtis tv model LCD2425A it was working ok untill today .MY tv is connected to dishnetwork my tv says scan channels did this still can't get any thing had this tv about 3or 4 months.tried...
The tv only 3 or 4 months olds take the tv warrenty repair or return it were u bought it trade it in for another new tv.This tv the main tv Tuner signal itself have problems,if after scanning channels and come up with nothing.
I just hooked up my Curtis lcd2425a tv and get no picture or sound. Just a white screen.
It might be the cable not the tv... Try hooking up an xbox or ps3... If the picture comes up on that then have someone come over to your house to fix the cable... If it doesn't work then send in your tv for a new one... Best if luck
1helpful
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
5helpful
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
Top Curtis Televison & Video Experts
Mike
mark warfield
mark warfield
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
