SOURCE: replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
SOURCE: My Poulan Pro BVM200VS leaf blower just stopped
sounds like an engine seizure - was there oil mixed with the fuel?
SOURCE: I have a Poulan Pro Leaf Blower, Model No.
Oil to gas.
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
Plug gap
0.025 inch (0.6 mm)
Or you can get the manual on the link below.
http://www.mowersdirect.com/manuals/BVM200VS_Man.pdf
Good Luck and please rate 4 thumbs up for free answer
Testimonial: "Thanks for a quick answer! 4-thumbs up! Bob"
SOURCE: fuel lines poulan bvm200vs gas blower
You need to split the entire unit to get to the fuel tank. Remove carb, remove exhaust, and remove right side of plastic enclosure. Check the cylinder to make sure it is tight, these units are notorious for the cylinder coming loose. Remove the tank and install your new fuel lines, leave them long then trim to fit once reassembled. Check to be sure the isolator mounts and starter rope ferrule are in place when reassembling
