I have a Samsung 55" LCD/LED TV, a UN55D6050TFXZA, I get some picture and great sound since I just replaced the power board, though the back plate of the tv is off, is that why My led backlit picture is dark?
Was the set dead before you replaced the power board?
Testimonial: "Yes, it had no picture and no sound, the red led was blinking, now I get sound, some picture, and I can change channels."
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: trouble locating correct location for tv on/off sensor
i have phoned bose the tv sensor will not work with led tvs becouse they do not transmitt enough power for the sensor to pick it up
SOURCE: samsung r20 laptop screen dark no backlit but can
Laptop screens often have several bulbs incorporated in the screen. Most oftern, the screen itself must be replaced. You can go on the samsung website and look up specifications on your laptop model. Some sites also have the option of chatting with a tech support person. If so, they could give you answers about the LCD screen on your laptop and if you can replace parts of the laptop screen or if the entire screen needs replacing. Is your laptop have any warranty coverage?
SOURCE: Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
