Question about Frigidaire Dishwashers
My Frigidaire dishwasher has a number 8 and will not work. Tried to flip breaker off and it's still there and will not work ser.#TH21288119- mod#FGHD2433KF1
Posted by Tanya Pate on
5 Related Answers
Anonymous
  • 1142 Answers
SOURCE: frigidair dishwasher mod#fdb1500lfco ser#th65267002
do a hard reset to the device
Posted on Jul 07, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Posted on Jul 17, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Kitchen Aid dishwasher has no
Welcome to FixYa.
Based on your brief description, I'd suggest you likely have a faulty thermal fuse in the control board as you alluded to, but it is not resettable unfortunately.
It's pretty easy to replace or to check, I've attached a link below to change the fuse, but you can also use the link to access the thermal fuse to check it.
With the aid of an ohm meter, remove one wire and measure across the two contacts and it should show continuity, otherwise it's open and therefore no good.
The part is available at most brick & mortar part places or on-line at vendors such as "repairclinic.com" or searspartsdirect.com" to name a couple. Part number 8193762...looks like this image and retails for about $15-$20USD based on the model you provided.
This is the youtube link to help with the repair "how to".
http://www.youtube.com/watch?v=jdlVbTXm8SY&feature=player_embedded
Let me know how you make out or if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Apr 17, 2011
Anonymous
  • 4323 Answers
SOURCE: Dishwasher leaking from bottom of
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 28, 2011
jumptrout51
steve
  • 3361 Answers
SOURCE: My Frigidaire fghd2433kf1 is not
If you recently replaced the garbage disposal the dishwasher knockout has not been removed. OR the dishwasher drain hose is not high enough and water is leaking back in from the sink.
Posted on Aug 27, 2011
Frigidaire dishwasher no power
Hello Tammy, I appreciate your post!
From my understanding your Frigidaire dishwasher has no power. You may need to review your circuit breaker located inside of your home to assure that the breaker has not been flipped. If the breaker is operating properly it could be a possible issue with your control panel or wiring. I would recommend having a professional out to your home to assure a proper diagnosis has been completed on your dishwasher. I hope that this information is helpful to your dishwasher repair. -Matt
Apr 21, 2016 | Frigidaire Dishwashers
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My Frigidaire Dishwasher Model #FFBD2411NWOA won't turn on at all. I flipped the breaker switch and also checked the disposal which is on the same breaker. That is working. The dishwasher was working
Good Afternoon Friend, this is Z. Thank you for your post!
I understand your Frigidaire dishwasher (FFBD2411NW0A) will not start. Let's try resetting your dishwasher by flipping the household circuit breaker to the off position once again. It is necessary to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. Best!
Aug 26, 2014 | Frigidaire Dishwashers
How do you reset the pump for this dishwasher
Hello friend, that's a great question!
To perform a manual reset on your Frigidaire dishwasher you would need to disconnect power to your appliance. The best way to do that is flip the household circuit breaker for roughly about ten minutes. Hope this is helpful. -Matt
Aug 20, 2014 | Frigidaire Dishwashers
What year is ser#TH73779721
Hello Friend, that's a great question!
According to the serial number listed above, I show that your Frigidaire dishwasher (FDB1050RE) was produced in 2007. Hope this helps! - Z
Jun 07, 2014 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire dishwasher model fgbd2431kw1 not working after power surge
Good Morning Cary, I am happy to assist you!
Let's try resetting your dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Nov 02, 2013 | Frigidaire Dishwashers
8 sec light on and no other buttons work
Hi Jennifer - Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jul 12, 2013 | Frigidaire Dishwashers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
I need to flip my circuit breaker on my dishwasher to make it work
you may have to many large appliances on the same circuit. you might try to
see how many appliances are on that circuit. if it is so try turning off other appliances and just run the dishwasher to see how it runs. if this works you
may need to increase the amperage on the breaker or split the electrical
circuit. if its on its on breaker try increasing the breaker amperage. good luck!
Jul 23, 2010 | Frigidaire PLD4555RFC Dishwasher
Dishwasher won't power on.
We're having the same trouble. What eventually happened?
May 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
