Hi Leonie.
Please allow me to try to help you.
The reason why you get the - please wait message on toshiba e studio 205, could be because the HDD has become corrupt. Another for this could be a fuser error.
You can find more answers to this issue -
https://www.manualslib.com/manual/1058435/Toshiba-E-Studio165.html?page=135
http://www.copytechnet.com/forums/toshiba/87173-toshiba-e-studio-452-showing-wait-during-copying.html
http://theoryreport.com/technology/toshiba/toshiba-e-studio/fix-the-f10-error-code-on-your-toshiba-e-studio-copier.html
Attached is a tutorial that might help you gain more insight into this issue.
Hope that helps.
Best wishes. Regards.
SOURCE: TOSHIBA e STUDIO205Series network scanner setup
its fairly simple, you need to obviously log onto your top access feature and just enter under admin all the relavant SMTP Server / Client details... your mail transport address maybe in IP form or its name (DNS) not to difficult, then obviously add an address to practise on and bombs away!
SOURCE: Toshiba Scanner E Studio 205
U can download the latest viewer at below:
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Everything is inside the application, just follow the instruction.
SOURCE: scan to e-mail toshiba e-studio 205
Easy reply would be to make sure you have an email application installed on your computer such as Microsoft Outlook or Outlook Express. That will have to be setup first, and might require some information from you internet service provider. Many people think that if they have a personal email account such as Yahoo or Hotmail, that this will communicate with the scanner. The scanner program installed on your computer wants to transmit your scanned documents to an email program that is also installed on your computer. Otherwise, scan the document to your hard drive, and then attach it to a yahoo/hotmail email manually. Hope this helps clear things up.
SOURCE: sir i have Toshiba e-studio 163 please tell me how
The toner detection is on the toner cartridge itself, where u can see the small PCB board. Try change another toner unit.
SOURCE: i have scan utilities cd of toshiba e.studio
The scan utilities cd only contains driver.
If your scan button is working, u can select scan to twain.
Install file downloader, and u can download your scanned files.
