Phone is Panasonic kx-TGE210 ,NOT A CELL PHONE
SOURCE: HOW DO I UNBLOCK A BLOCKED PHONE NUMBER
Go to: MENU press: # Enter direct No. :217 Search number then Erase or Edit
SOURCE: How would I unblock a number that has been blocked
try going to the menu and search for anything related to blocking numbers. and select it and it should have a list of numbers youve blocked, and you should be able to delete them.
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
SOURCE: I accidentally blocked my cell
Do the following:
Select MENU
Select INITIAL SETTINGS
Select CALL BLOCK
Find and ERASE the number you want to remove the block from.
