SOURCE: Electrical hook up for 2
yu can't do it with off the shelf detector. Sine the detector is single input.
you need serial and parallel input to the device.
you need to get commercial detector that haev serial and parallel input to the detector.
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
SOURCE: wiring diagram 3 way motion detector switch
mike
can you send me a picture of how you wired your switch..its driving me crazy...
[email protected]
