Cameras Logo
Question about Sony Cameras
Need circuit diagram for 19.6 volt sony ac adapter
Posted by gopalswamy gopalwamy on
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Posted on Oct 28, 2008
pontelemon
pontelemon
  • 538 Answers
SOURCE: FujiFilm S7000 ac adapter not working
Yes, it is sounds like a fuse(s).
Posted on Apr 23, 2009
jscuin6
  • 132 Answers
SOURCE: ECS Green320 laptop , dead , no beep sounds good
Remove battery , attach ac power , turn on , if the laptop still has problems you've at least ruled out battery fault , sounds like faulty hardware somewhere alright but where??
Posted on Feb 08, 2010
Gyula Lacz
  • 486 Answers
SOURCE: Need circuit diagram Sony TC-K511S cassette deck
You can download it for free from here:
http://elektrotanya.com/sony_tc-k411_k511s_sm.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading so please be patient.
Thanks.
gylacz
Posted on Aug 29, 2011
Testimonial: "Thank you for the service - it's almost impossible to get onfo. on older mechines from the manufacturer."
Michael Kennedy
  • 233 Answers
SOURCE: Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Posted on Oct 18, 2012
I got this laptop to check it because it does not turn on. I have checked the AC adapter and it gives 19 volts for only two seconds and then it goes stable to 1 volt. Could it be the ac adapter?
Yes. The power supply should provide 19 volts continuously when plugged in. You can get replacement ac adapters pretty inexpensively on eBay. Make sure that the wattage (and/or "mA" rating) of the new adapter is equal to or greater than the current one.
Also be sure that the connector is the right size for your laptop. Most suppliers have a compatibility checker on their webstore to make sure that the connectors are compatible.
Where to get gharging cable for veco12cbd
Here is a generic replacement charger at a good price. I measured the open circuit voltage of my charger and it is 18-19 volts.
HQRP AC Adapter Charger for Black Decker VEC012C TYPE 1 VEC012CBD TYPE 1...
Packard Bell Problems
Check your laptop DC jack loose connection or not. Your AC Adapter is giving accurate voltage or not mostly all laptop works with 19 volt.
Remove battery and unplug AC adapter. Press and hold power bottom for 30 sec. Now plug the AC adapter and placed the laptop battery and Turn on.
If still not working need professional repair. You can be, but have to go throw with many things.
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
1helpful
Laptop not powering
Sir,
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOWPUT IN BATTERY
AC power adapter How the AC adapter worksThe most common type of AC power adapter involves a small box, withone wire to go to the computer and another wire to go to the wall.There is usually an LED light on it, to tell you that it is on. (Is itlit on yours?) By the way, Apple notebook power adapters often have anLED that is actually built into the side of the computer, not into theadapter box, so obviously it won't light up when it's not connected tothe computer.
The power adapter box does several things. It lowers the voltage from the wall's 120 volts AC to typically 19 volts DC (it will be labeled with the exact voltage). It includes some power noise filtering. It often includes an automatic circuit breaker or overload detection. If this gets tripped, you can generallyreset it if you unplug it from everything for a few minutes.
You can measure the voltages on your AC adapter with a multimeter. When it is unplugged from the computer but still plugged in to the wall,it is normal to find that the voltage may be 1 to 3 volts higher than theprinted output rating.
Troubleshooting: AC Power adapter LED is off when you plug the adapter into the wall but not into the computerHas it been overloaded? Is the power strip turned on / is the outlet working? Is the cord from the adapter to the wall fully plugged in on both ends (try wiggling)?Your adapter may be fried- try borrowing an indentical adapter from a friendand seeing if that one will work in it's place (but do not plug it in to your computer, or you might fry your friend's adapter).
Troubleshooting: Check output voltages with a volt meter/multimeterFor those of you with circular connectors, your task is easy. Measure the voltage between the inside and theoutside. A diagram on the adapter's label will tell you which should be positive and negative
For those of you with the 3-pin Dell power connectors, I don't have a diagram for you yet, sorry.If you try measuring each of the three possible pairs of pins, you should get 20 volts between oneof the pairs.
Power distribution inside the laptop How laptop power distribution worksvoltregulator.jpgOkay, the power comes into the plug on the back of the computer. This connects it to metal tracesinside the mainboard of the computer. These will be connected to voltage regulatorswhich often output 5 volts, 12 volts, 3.3 volts, and the CPU voltage; they sometimes look like the image at right.
These will be connected to cylindrical capacitors distributed throughout the mainboard. Capacitorsact like tiny, fast batteries, supplying extra power where needed to maintain a steady voltage during high demand.
Finally, power goes to all the devices that need it.
Power for the LCD display is usually done seperately. Generally, LCD backlights require high voltage to operate.A component that might be called a power inverter will step the voltage upto what is needed for the backlight. Sometimes this inverter is a discrete andreplacable component, and sometimes just a chip on your mainboard. It is also involved in the brightness control.
The battery is an important part. It supplys power to theinput-side of the voltage regulators, just like the power from the AC adapter.Additionally, there is a charging circuit, which uses the power from theAC adapter prior to the voltage regulators, to charge the battery. (By the way, this is why the AC adapter voltage is always rated higher than the battery's rated volatge-- you need higher voltage for charging.)
There is a separate page exclusively for Laptop Battery Problems.
Short circuitsAnywhere in your laptop, physical or electrical damage can cause a short circuit.A short circuit will consume all available power, causing your laptop to not turn on.If your power adapter LED comes on when you plug it into the wall, but then goes offwhen you plug in the laptop, you probably have a short circuit.
Troubleshooting short circuitsAn ohm-meter / multimeter will read less than ~3 ohms when you measure theresistance between sides of power going into a short circuit. When measureing betweenthen power pins going into the back of your computer, consider the 2 pins whereyou expect voltage to be applied by the AC adapter. If the resistance indicatesa short circuit, this is bad.
A common trick to help isolate possible problems is to try to removing anything that mightbe a short circuit. Take out the battery, the hard drive, the DVD/CD drive, the floppy drive, PCMCIA cards, USB devices,miniPCI cards. See if the computer will then turn on.
You might have luck with a thermal imager (see story below) to find a hot spot caused by theshort circuit.
Spilled liquidLaptops exposed to small amounts of spilled liquid are repairable in some cases. Liquid can cause the following types of damage:
  • Short circuit due to wet liquid (problem goes away after liquid evaporates)
  • Short circuit due to dried liquid residue
  • Corrosion (especially bad with soda such as Coke or Pepsi)
  • Electronic components damanged by above short circuits
Immediately when a spill occurs, you typically want to turn off thelaptop, turn the laptop upside down (so the liquid goes out the sameway it came in), remove the power and battery, and allow to dry atleast overnight.
To remove dried liquid residue: Try removing the keyboard andcleaning any components that have dried liquid, by using distilledwater and Q-tips.
Computer turns off randomlyYour computer can turn off due to: power overload in the AC adapter,overheated processor / clogged fan,overheated battery, pushing the power button, Windows telling it to,the BIOS telling it to, loose wires (especially the power cord), orintermittent short circuits.
The most common problem is cooling. Try going somewhere air conditioned. Notice if the fan isbroken or clogged with dust (common older HP problem).
Thanks
Good Luck
Gateway 405ROG AC Adapter Output Polarity
it doesn't matter if its + or - , make sure the pc runs on 19 volts and that the AC adapter does also, look underneath the laptop to find out if it does run on 19 volts but make sure the power jack fits the socket o the laptop before plugging it in to the mains
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
