Question about Panasonic Cameras
Where do you connect the USB cable to a Panasonic DMC-ZS8?
I have the cable... can't find the place to connect it to the camera.
Posted by Norma Stiles on
1 Related Answer
Anonymous
  • 313 Answers
SOURCE: I need a manual in
You can view it HERE
I hope I helped you!
Posted on May 19, 2011
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Feb 12, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
How do I get the date/timestamp to display on pictures with Panasonic Lumix DMC-ZS8?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 30, 2013 | Panasonic Lumix DMC-ZS8 14.1 Megapixel...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
How do I upload pictures from a Panasonic DMC-ZS8 digital camera to a laptop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 25, 2012 | Panasonic Cameras
How do i transfer pictures from a Panasonic DMC-ZS8 to my laptop
May 25, 2012 | Panasonic Lumix Dmc-zs8 14.1 Mp Silver...
I cant get my Panasonic dmc - zs8 luminex to the computer via usb cable so i can take the pictures off and put it to my computer. Can anyone please help me i would really appreciate it.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 21, 2011 | Panasonic Cameras
Cameras Logo
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
