Question about iLO Televison & Video
How to change an ILO gaming tv to cable tv - iLO Televison & Video
Posted by Rita Brumley on
How do I hook up my digital cable to my ilo flat screen TV with out a box
It won't work because the tuner from your ilo TV will not be able to decode the digital signal from the cable company even if your TV has a digital tuner. The digital tuner on your TV will only decode over the air signals.
You will still need the digital cable box from the cable company.
Aug 03, 2015 | iLO Televison & Video
I have a ilo tv model 26hd it's stuck in cable mode
Go into the menu with the original remote and in the setup should be a selection for cable or air/antenna------you likely need the original remote to do this.
Oct 29, 2012 | iLO Televison & Video
I need to change my Ilo tv from "Digital" to
This is done in the menu through cable or air
Mar 05, 2011 | iLO 3200 32 in. LCD Television
I have no remote and can't change inputs
well most tvs come with a game in put that you can change on your tv menu but if you cant you will need a universal remote
Oct 25, 2009 | iLO IWT3206 TV
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Encrypted channel
Contact them here
http://www.funai-corp.com/support/contact.aspx
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Televison & Video Logo
32 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
