Microwave Ovens Logo
C
Cheryl Rice Posted on Nov 05, 2017
How do I unlock the control panel of a ge microwave oven?
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 05, 2007
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Anonymous
  • 4 Answers
  • Posted on Nov 29, 2007
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 27, 2008
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Anonymous
  • 87 Answers
  • Posted on Oct 03, 2009
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Anonymous
  • Posted on Feb 21, 2010
SOURCE: GE Dual Wave II microwave oven blowing fuse
I have the same issue and the same unit. I wonder if there's a recall...
3helpful
2answers
I locked my buttons on my ge spacemaker microwave by accident. How do I unlock it?
I did same thing tried everything be pressing and holding the off button about 5 seconds it worked.
15helpful
1helpful
Control panel is locked.
Pres the "Clear/off" button and hold it down for six seconds. The panel will unlock.
6helpful
2answers
My control panel has locked and I can't unlock it.
If this is a GE Spacemaker model, you can lock or unlock the controls of the oven by pressing and holding the CLEAR/OFF button for 3 to 5 seconds. If this is not a GE Spacemaker, please post back with your correct MODEL NUMBER. I hope this information helps you.
7helpful
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
6helpful
Control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
3helpful
Control locked
If yours is a GE JVM1640 or similar GE model, here's what the owner's manual says:
To lock or unlock the
controls, press and hold
CLEAR/OFF for about
three seconds. When the
control panel is locked,
an “L” will be displayed
to the extreme right.
We're happy to help and we appreciate your thoughtful rating of our answer.
4helpful
LOCKED panel
to lock or unlock the controls.press and hold clear/off for about 3 seconds.
When the control panel is locked,an "L" will be displayed to the extreme right. Then vice versa.
5helpful
Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
4helpful
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
