You can reset your Epson R360 printer to get rid of various printing problems. To reset the printer, you have to disconnect your printer to the power and remove the connection between your printer and the computer. Later on, you can connect it again and restart your printer. If you need the in-depth instructions, call on the Epson customer care number to get instant customer support and step-by-step guidance to reset your printer. Epson Printer Tech Support Number 888 604 2301
Hi there.
look and see if this link will help you out.
how to reset my epson printer r360 Google Search
SOURCE: EPSON R360 ERROR MESSAGE.
its the reservoir on the left side , power off the printer , open and then with a light see the small square suction area on the left side ,
poke some paper towels in hole and it will start absorbing the ink.
it is messy so watch it. use gloves.
SOURCE: Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
SOURCE: MY EPSON SYLUS T10 PRINTER STOPPED PRINTING AND
go on this link:
http://inksystem.vacqum.com
They have resetters and adjustment programs for Epson T10.
SOURCE: printer epson stylus T1100 blinking,bagaimana cara
silahkan sedot di http://resetterprogram.blogspot.com itu adjusment pake bahasa rusia conek aja ke komputer terus klik reset
