Question about Locks & Locksmithing
Battery has been changed in my winchester gun safe. red light is blinking. i punched in code and does nothing. no beep no nothing. what can i do?
Posted by ann derfler on
Steve Horne
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
It's probably in penalty mode wait 5 minutes and see if it acts differently. If it's in penalty, every time you push a button it starts penalty over again If it does you may have a bad keypad
call your local safetech and he should be able to troubleshoot it and fix it
Posted on Mar 23, 2019
2 Related Answers
SOURCE: sentry safe, enter codes and nothing
These safe are easily opened by a good locksmith. So if you have items in the safe you need to get out a safe and vault tech could drill it open and repair it for a small fee. I really don't think it is the chip probably just a stuck solinoid.
Posted on Aug 08, 2010
Anonymous
  • 132 Answers
SOURCE: I changed the battery in my winchester digital
was there not a key also? if not then remove the new and start over, if it still wont open refer to your paperwork that came with the unit there is always a number to call for questions.
Posted on Oct 16, 2010
How do I change the battery on a winchester gun safe door?
Winchester uses several different brands of locks. You need to be more specific as to the lock that is on your safe. However, most batteries are contained in a housing on the under side of the code entry pad.
S&G batteries are usually removed by simply pulling slightly forward on the tab on the housing on the base of the lock. The housing will then drop down and you can change the battery.
Some locks will actually have the battery contained inside the code entry pad housing which can be removed by grasping the entire key pad housing and rotating the housing a few degrees counter clockwise, and then pulling the unit straight toward you.
Some locks may require you to remove a screw, but most do not.
A more specific description of which lock is installed in your safe will allow for a more specific answer. A picture also helps.
Mar 01, 2015 | Optics
Red light blinks 6 times on winchester furnace
should be a code chart on the inside of door.
Apr 01, 2014 | Winchester Heating & Cooling
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
I have a Regent digital electronic safe model MOT SFN37E. I still know my code, but after changing the batteries I can't open it any more with my code. I also lost my key.
If you can get the door open (which I've seen several procedures for), you can reset the panel with the red reset button on the inside of the door on the hinge side. It will beep and the orange LED will light up solid. Now you can type your 4 digit code, press B, confirm code, press B again et voila!
Jul 19, 2012 | Safe International Digital Electronic Safe...
I changed the battery in my winchester digital safe while the door was closed. after i changed the battery i punched in my code and the door will not open. it beeps twice indicating that i punched in the...
Oct 16, 2010 | Winchester (026196062448) (20 - 60x70 mm)
Where do i get instructions for changing the code on my hardline digital safe. The instruction paper that came with it appears to be for another safe. the paper mentions a red button where no red button...
I had this exact same problem. Then I realized the red reset button was actually INSIDE the safe itself. So you need to enter the factory default code "159" to open the safe, then on the inside of the safe next to where the batteries are is a red button. If you press that, the yellow light will flash and you'll get two beeps. That means you can now enter your own combination. I hope this helps.
-Mike
Jul 06, 2010 | Safe International Digital Electronic Safe...
Sentry safe, enter codes and nothing
Motorola IC #MC68HRC705 will not reset. Chip is most likely bad. Time to throw this safe out...Thanks for your answers. George
Mar 25, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
1,646 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
