Computers & Internet Logo
Question about The Computers & Internet
I forgot my password to my Defender Security DVR, online support says they will only respond by email in a few buisness days and only if so info matches their system, and I have no clue as to the date I purchased this! Is there a way to hard reset this or is there an override password?
Posted by Jennifer Robinson on
TheDrive
    New Friend:
  • 12 Answers
Please think twice and realize people can not help you when they do NOT know what the particular device are you talking about!
What the particular model of the Defender DVR device you are talking about?
Here is an article about hardcoded support passwords in some DVR's including some Defender DVR's (a brand of Circus World Displays), which (may be!) you can use to access your device.
https://www.networkworld.com/article/3034261/hard-coded-password-exposes-up-to-46000-video-surveillance-dvrs-to-hacking.html
Read carefully and look if this info related to your case.
Search with Google info on your particular model, it's internals and access methods. Most of advanced network DVR's contain Linux-based firmware, so there are good chances for hackers to explore firmware internals and find useful things.
In the modern world any devices may be produced by any manufacturers and sold under any brands. Thus, internal architecture of the particular device and its real properties is highly depend not only on the particular device model, but even its hardware revision. E.g. many network devices having the same brand, the same model, the same casing, but JUST ONE different letter in the revision string could have been made by absolutely different real manufacturers and have absolutely different boards, CPU, hardware configuration and firmware.
It's a real fraudlent world and stupld 'money making Matrix system', we built. Forget about brands. The only countermeasure we have is our wide knowledge and accuracy.
Posted on Nov 05, 2017
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Posted on Jul 09, 2009
Anonymous
  • 712 Answers
SOURCE: I forgot the password for my Defender Sentinel1
It can be reset only by the company and not others. Contact the care center to reset the password.
Posted on Oct 08, 2010
Anonymous
SOURCE: I have Dahua dvr 1604
dont remember, just visit manufacturers web site www.dahuatech.com
Posted on Jun 13, 2011
Anonymous
  • 24 Answers
SOURCE: Hi can anyone advice me
Get the 12 digit alpha numeric mac address off of main board and call your tech support. They should have, as I do, a keygen for the master password for that main board. Any reputable dealer will have the MacCov program from Rifatron.
Posted on Dec 27, 2011
hepcars
Howard Pfeiffer
  • 1249 Answers
SOURCE: How do I reset the date display? The date doesn't match the day of the week.
A very nice car...you really deserve to get a copy of the "owners manual" Many things to know about these quality sporty cars...
Posted on Jul 31, 2012
How can i reset the password on my clover dvr
limited info generic answer notify manufacture for assistance
2answers
3answers
ANNKE DVR standard cctv cameras forgot my password cant view recording is there a way to reset the dvr
Annke DVR Password Reset
Like, Share and Subscribe Channel : https://www.youtube.com/channel/UCxAhv5XWrbpjvdfVBVEHCMA
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
The security camera on my phone quit working. need to fix it please?
Hello there,
You need to first save the settings info by jotting down all addresses and passwords. Next, uninstall the software and restart your phone. Re-install the software, in so doing look for an updated version if possible. If this does not work, then open your DVR software settings and check your Mobile settings. Make sure that the user name and password still stands. This includes your server port. That should fix it.
Wont take email or password
Hi Ken, most sites have a "Forgot Password" or "Reset" link somewhere on the sign in page - on some, you may have to fail to login a few times before it automatically asks if you want to recover your account.
Mot sure which site you are having trouble with, but you may want to consider using a free password manager to save your login info going forward - this also keeps your passwords more secure because you don't need to type them, and makes logging in faster. We offer a free password manager you can install in a few seconds to try it out!:
The Key to Your Online Security SpeedyPassword
Recover passwords
if the password for email that is associated with the xbox live account, simply call microsoft xbox, and answer your security question, if you set a security question, if not, simply answer all the account specific you input on the first day you create your gamer tag.. =)
2answers
I forgot my gmail password
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Dec 14, 2013 • gmail.com
I lost the four digit password to get online. how can i recover it ? i have play station 3
if you go to the sign-in menu all the way on the right you can choose "forgot my password" but then you must remember the security question.If you can not get threw that way try Click "Forgot Password". The Password Should come in your email. Or write playstation to resend your info to your email.There always the option of creating another account.
Top The Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
NADARK
NADARK
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
