Vacuums Logo
Question about Bissell Vacuums
I was vacuuming with my Bissell model 1309 and everything was fine and then all of a sudden now I'm not getting no power at all when I push the power button what happened and how do I fix it
Posted by Richard S Hicks on
5 Related Answers
Anonymous
  • 1673 Answers
SOURCE: Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Posted on Jun 03, 2008
Anonymous
  • 76 Answers
SOURCE: Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Posted on Apr 19, 2009
Anonymous
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
Anonymous
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
Anonymous
  • 276 Answers
SOURCE: The brush in my bissell vacuum does not work
Follow the link below to the belt change instruction video on Bissell.com.
proheat
-2x/">http://www.bissell.com/how-to-videos/replace-brush-proheat-2x/
Posted on Nov 16, 2010
3helpful
We all of the sudden have to hold the power button down to turn it on. As soon as we let go of the power button, the vacuum shuts off.
It sounds like the actual switch in the unit has failed. The switch has a spring in it that keeps it in the on position then pushes it to the off position when it is hit again. If you can get to it, you'll be able to check it out yourself and Bissell will probably send you one to replace it.
Gary
Whenever I push the Bissell Proheat the brushes catch on carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yrf45
2answers
My bissell 2x steam cleaner is not picking up the water from the carpet. What do I need to do?
heatman101
vxbv
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
1helpful
The Water will not spray out(it just dribbles) of the shampooer
heatman101
ewrtwy
2helpful
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
