I hit upper oven CLEAR & then tried to run the self clean, which it did lock & it ran the preset 3 hr cleaning with no error code. But when the 3 hrs was over the upper oven was cold & it wasn't clean. The bottom is working great. The oven is 1 1/2 years old (warranty ran out). The issue with upper oven not heating is about 2 weeks...been using bottom oven.
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
SOURCE: "Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
SOURCE: Kenmore oven locked after celf cleaning
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
SOURCE: code f9 on frigidaire self cleaning oven. what
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
