Question about Kenmore Cooktops
Kenmore ceramic top stove
Replace cooktop element
Posted by Teresa Allison on
5 Related Answers
Anonymous
SOURCE: how to fix a crack in ceramic top
Mine cracked and I ordered a replacement shipped overnight. I can't get a repair person out before Christmas. Is it easy to do it myself?
Posted on Dec 20, 2007
Anonymous
  • 93 Answers
SOURCE: Gagganau Glass Cooktop
www.foxatlanta.com
Posted on Jul 21, 2008
Anonymous
  • 111 Answers
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Posted on Dec 19, 2008
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: I have a cracked ceramic top on a thermadore induction cooktop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model Number is always helpful when requesting information.
This part should still be available from a local parts outlet. You'll need model and serial and color. Model and serial are located underneath the unit on its bottom.
You won't like the price. Good Luck
Posted on Aug 31, 2009
Anonymous
  • 159 Answers
SOURCE: westinghouse freestyle 521 stove ceramic
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
Posted on May 29, 2010
I replaced what I thought was a bad 9" heating element on my Kenmore glass top stove and the new element still does not work or even attempt to come on. what should I do next?
Did you check if electricity was coming to the element. Try putting a volt meter on the two wires and turn it on see if you get anything...could be a bad switch
Sep 15, 2014 | Kenmore Frigidaire Glass Cook Top...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Apr 25, 2010 | Kenmore 30 in.44084 / 44089 Electric...
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Dish towel stuck to ceramic cooktop
When they are really bad, I use a razor blade in one of those scraper holders. Finally a green scrubby with some comet....Once finished polish it with a very good cooktop cleaner and you will be looking good as new.... If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Whirlpool ceramic cooktop
Scott,
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
169 people viewed this question
Top Kenmore Cooktops Experts
Michael Thomas
Michael Thomas
Lawrence Oravetz
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
