The Pre Out and PWR In for a method to insert an effects loop. The output signal from the Pre Out should be line level so you would not connect this to our microphone input on the PA, but preferably to a Line Level input otherwise you would overdrive the PA's input. When you connect the Pre Out, the 1/4" jack may interrupt the signal so you may lose output to the Champion's amplifier/speaker. If this happens, you need to have a return line with the same line level signal plugged into the AMP In to get your sound back on the amplifier itself.
SOURCE: can i go straight out
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
SOURCE: where can I get my Fender passport PA system
Here ya go:
Authorized Fender electronics Service Center
