I sent my jp5 tablet off to be unlocked to use now I'm home.. It works fine but I can't install anything because there's no room , does it have an SD card slot or how can I mount SD card to my player
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
SOURCE: micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
SOURCE: Im using a tablet and I cant move apps and games
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
SOURCE: i have an irulu tablet. I inserted a 32gb sd
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
I am looking to buy an unlocked tablet. [email protected]
That was the wrong email. [email protected] is the correct one. Thanks
Hello, my friend,
I am looking to purchase an unlocked jp5 tablet, one that could receive internet services. If u happen to have one or know someone who do, please email me at: [email protected].
Thanks
