Question about Toyota Sewing Machines
Toyota 8000 sewing machine doesn't sew fancy stitches any more. I think the pattern wheels have seized up?
Posted by Wendy Widjaja on
R.A. Ellis
  • Toyota Master
  • 12,731 Answers
Very possible the parts have seized if it is a mechanical machine. Not knowing your machine, I would think lubing with a clear oil (like Tri-flow Synthetic Lube or good quality sewing machine oil) may help if you can get to those parts. Avoid any computer parts, plastic/nylon gears, rubber belts. On the other hand, a thorough service call could be very beneficial for more than just fixing the stitch selector.
Posted on Nov 03, 2017
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
Anonymous
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
Anonymous
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
sewtexas
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
paj42
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
Can I embroidery on my brother jx2517?
If you're thinking about one of those machines that you can load fancy embroidery patterns into and stitch them out on your machine, then "No." Your machine is basically a sewing machine, but it does have decorative stitches and, with practice, you can do some manual embroidery.
May 14, 2018 | Brother Sewing Machines
My Bernina 801 is stuck in the tack stitch. How do I get the regular stitch back??
Hm, am wondering if it is seizing. How long since it has had a thorough clean and oil? Seizing happens when the old oil dries and begins to stick the machine parts.
Wheel on right side that controls the needle up and down is very tight...
Dec 06, 2017 | Bernina Sewing Machines
My old 830 will not do zigzag stitch are any other fancy stitch. Will only straight stich
Most likely, it has seized due to old oil that has dried. These old machines do love regular oiling and cleaning. Usually the first to be affected are the stitch selectors, feed dog drop, needlebar or handwheel.
Aug 30, 2017 | Sewing Machines
I have turned my dial to the zigzag option, yet it is still sewing a straight stitch. How can I fix this problem?
UPDATE: It appears that your machine is computerized. Probably best to take it for service. Oiling will most likely damage your machine and do nothing toward resolving the issue.
Please provide the make & model of your machine. If it is a mechanical machine, most likely the machine has seized so that the needle does not do the appropriate swing for zig-zag or decorative stitches. A good cleaning and oiling with fresh, good quality sewing machine oil will take care of a mechanical that is seized.
Will not zigzag or decorative stitches New to these newer plastic style...
Jul 31, 2016 | Sewing Machines
I have an older New Home Sewing machine XR-V11 electronic I have figured out the threading, bobbin, regular stitching and back stitching. It has alot of fancy stitching on it I can get the dial to move to...
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Mar 06, 2010 | New Home HF-2022
My Bernina 830 Sewing Machine is not sewing the 1-20 stitches, only straight stitches.
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Oct 23, 2009 | Bernina Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Toyota Sewing Machines Experts
Marvin
Marvin
gbob59
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
