It sounds like there may be an issue with the power supply to your Yamaha Electone HS5. Here are a few things you can try to troubleshoot the problem:
Check that the power cord is securely plugged into the back of the Electone and into a working outlet.
Make sure that the outlet you are using is functioning properly by plugging in another device to see if it powers on.
If the power cord and outlet seem to be working properly, try resetting the Electone by unplugging it from the wall and waiting a few minutes before plugging it back in.
If none of these steps help, there may be an issue with the power supply unit inside the Electone. In this case, it is recommended to have the instrument serviced by a qualified technician.
checked the internet and it states in the manual that if you do not use the organ for long time the user memory will be lost but the factory memeory will not be affected. check the below link:- http://archive.org/stream/YamahaElectoneHsUsersGuide/YamahaHsUsersGuide_djvu.txt
the problem is the main output amp. It is an IC so it is better left to a tech to put it in. Just had the same problem with mine. Seems to happen when unit is left on overnight.
Have you tried joining at the Electone Zone at www.electone.com? It looks like a fun site and its free to join. Maybe one of the members there can kindly help you.
