Radio Communications Logo
Uh089 uniden says error when i press scan - Uniden Radio Communications
Uniden scanner won't scan
If your Uniden scanner won't scan, there are a few things you can do to try to fix the problem. The first thing you should do is check to make sure that the scanner is properly plugged into an outlet and your computer. If it is plugged in and still not scanning, try restarting your computer. If that doesn't work, you may need to update the scanner's software. You can download the latest software updates from Uniden's website.
1helpful
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Why does it say error after entering a frequency then pressing E/PGM?
An ERROR message during programming normally means that you've entered a frequency that is outside your scanner's tuning range. Check your operating manual for ranges that are covered by the scanner. Need the manual? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC370CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
1helpful
When switched on L/O appears all channels read zero,wont accept data such as frequencies keeps showing error.
Hi, my name is John. Welcome to FixYa. Turn on the unit and Press FUNC then press and hold L/O button until it beeps twice then press scan. Thanks for choosing FixYa.....John
3helpful
How do you program a Uniden Bearcat bc244CLT?
To program a known frequency into your scanner:
- With power ON, press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program (01 - 30).
- Press MANUAL.
- Enter the frequency, including decimal point (for example, 156.065).
- Press E to enter/store the frequency into memory.
- Press MANUAL to advance to the next channel for programming.
For more information, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC244CLTom.pdf
Bill B
My uniden bc350a police scanner is not scanning frequencies stops on one and stays
Press manual,adjust the squelch to where it is silent,press scan. hope this helps..
4helpful
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
• The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
BillB
2helpful
How do i program my BC 55xlt uniden scanner?
To program:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
Pressing Lockout will toggle the status.
To program:
Select channel. Use keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
1helpful
2answers
Cant program frequencies into my uniden bc72xlt scanner
Just to verify you are trying to program frequencies the scanner is able to receive.
This unit is limited to the following freq range.
25.0-27.995
28.0-29.695
29.7-49.995
50.0-54.0 5
108.0-136.9875
137.0-143.995
144.0-147.995
148.0-174.0 5
406.0-419.99375
420.0-449.99375
450.0-469.99375
470.0-512.0 6.25
If the frequencies your are trying to enter or outside these bands you will get a error.
Next Direct Entry Mode Programming
Press Func. + PGM
Press E to enter ch in current location
To change location pres func + Up ^ or down key to choose location then press E
Enter your freq then press E
Hope this helps.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
