Question about Hisense Televison & Video
I need a remote control for my hisense tv - Hisense Televison & Video
Posted by Allan jones on
Robert Flinn
    New Friend:
    Problem Solver:
  • 6 Answers
Many universal remotes have codes to operate with Hisense TVs.
Posted on Nov 03, 2017
NOEL
    Top Expert:
  • Hisense Master
  • 8,555 Answers
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Anonymous
  • 1124 Answers
SOURCE: Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Posted on Oct 17, 2008
Anonymous
  • 119 Answers
SOURCE: I have a Hisense TV,
Hello tacey55 and welcome to FixYa. I have compiled a list of your Hisense television codes below.
hisense LHDN32V66AUS 32 "...Hello Four digit universal remote code for Hisnse TV are:- 0073 0182 0216 Code Entry Press and hold the SETUP button until the red indicator stays on, then release the">0073 0182 0216
If your remote only accepts three digit codes just remove the first zero off of the codes I provided. Example 0073=073.
I hope you found this helpful tacey55 and thank you for visiting FixYa.
Posted on Apr 26, 2011
Anonymous
  • 78 Answers
SOURCE: Remote control code for a
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
Posted on May 03, 2011
gopakumarg43
  • 76803 Answers
SOURCE: need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Posted on Dec 19, 2011
4helpful
I need a remote control code for a hisense tv
Hello
0073 0182 0216
10748
2helpful
11answers
Hisense tv
so whats the remote you have there?
6helpful
4answers
Hisense Remote
1helpful
I need a3 digit code for a ge remote for a hisense 42' flat screen
There is no three digit codes fr Hisense TV with GE remote controls.
6helpful
2answers
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
1helpful
I need a new remote control for hisense tv flat panel, where can i buy one?
I've had very good with the Radio Shack Universal Remote. It recognized everything I had. Try that, because if it doesn't work, you can take it back for a refund.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
