While watching a football game, the scores that are shown on the bottom of the screen are not fully visible and the block of score and downs to the right are also only partially visible in the Just Scan mode. Normal and Cinema modes are worse.
Try going to video settings on your tv. Change settings to 4:3/16.9/auto. Some times even panorama view can create this problem.
Instead of trying to make the TV display the picture the right size I suggest you adjust it at the source. If it is a cable box or sat box there should be a display adjust capability to size the display to the native resolution of your TV.
SOURCE: Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
SOURCE: Can't see scrolling text or sport scores
Here's how to fix it - I have a PF 2425, and it's driven me absolutely up the wall. Videogames are useless because you can't even see the crucial gauges etc. Likewise, subtitles and credits in films are cut off. it's ridiculous, especially considering how easy it is to fix (if you know how).
1. Decrease volume to 0.
2. Press MUTE so the tv says "MUTE" onscreen.
3. Hold MUTE on the REMOTE and MENU on the TV simultaneously until the service menu appears.
It's important not to screw around here too much. Use your arrows on the remote to navigate, the first option likely will say "MENU.0" or something like that. Use that to flip through the pages. What you're looking for are values like V Zoom, V Scroll, etc. Same goes with the H values. Toy with these a little and you'll be able to get the tv scanning perfectly.
I can confirm this worked for me! So good luck.
SOURCE: 32'' Toshiba Regza: Can't get the picture size to show all data.
An adjustment in the cable box fixed the problem.
SOURCE: The score on some football games doesn't display
I suspect you have the TV set to Smart or Expand picture mode. Go into the menu and re set the screen size to 16 X 9.
Hope that helps.
SOURCE: I have a Pioneer SD
It's likely that you've changed the screen format to a different ratio. There should be a button on your original Pioneer remote, marked "MODE" with "SCREEN" written above.
The change the screen ratio, put your TV on a channel where you can see sports scores or the news tickers, then press the "MODE" button repeatedly until they are the correct size and in the correct position. Each successive press of the "MODE" button will cycle through the options for "NATURAL WIDE", "CINEMA WIDE", "ZOOM", "FULL" and "NORMAL"
I suspect you have accidentally pressed the "MODE" button and are in "ZOOM" mode. You probably need to be in either "FULL" or "NORMAL" modes depending on your viewing requirements.
It may also be necessary to adjust the vertical (V) position on the picture. If you have changed the mode settings as above but it's still not correct, please post back if you need information on changing the picture position.
Regards,
BElectric
