Dirty evaporator coil, dirty air filter, weak blower motor windings, weak blower motor capacitor, wrong blower speed, leaking or broken ductwork, uninsulated ductwork, gas valve pressure needs adjusting(low fire)? Might be any or all of the above.
Model and serial number are needed for an accurate answer. Initially look for good airflow and good exhaust.
SOURCE: How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
SOURCE: Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
SOURCE: Coleman Evcon furnace, blower runs
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
