I know it's a pargo but that's roughly it, I don't have the motor tho the hook ups imply its a electric with 4 wheels and the serial number plate said columbia car
Hi lonny.
not sure if you will find it at this link but have a look.
year of pargo golf cart serial number 370348 Google Search
Testimonial: "Yeah I tried that exact search sadly all I know from that is its from before 1980 and after 1965"
sorry this did not help you out much.i will keep looking and if i find anything more i will get back to you.
I found it but I still don't have a good year, it's the blue one up front exactly.https://www.vintagegolfcartparts.com/Ite...
ok i will carry on looking for you.
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
SOURCE: the electric motor comes on but the engine does
Is the motor turning? Only one fuse and the starter will not turn if it is bad. If the motor is not turning, make sure the belt is not slipping. If it is not slipping, make sure the engine will turn by hand. MAKE SURE KEY IS OFF BEFORE YOU PUT YOUR HANDS IN. If it seems free, you either have a weak battery or the brushes in the starter have worn out. I change at least 20 sets of brushes a year on Club Cars.
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
