Question about Miscellaneous
Were do bats live - Miscellaneous
Posted by skylar reese covey on
John DuBois
    New Friend:
  • 3 Answers
Caves,attics,dark places....like the shadiest dark place in tree tops where all light is blocked. Deep Holes in side of dirt bank sometimes on vertical wall where dirt has been removed in so called pits....for clay for roads or other. Old barns too in top. I've seen them under porch canopy roof huddled together in farthest dark corner even.
Posted on May 17, 2019
Andrew Elmore
    New Friend:
  • 10 Answers
In a dark damp cavern
Kirk Whiteside
    New Friend:
  • 24 Answers
Some species, such as the Mexican free-tailed and gray bats live in large colonies in caves. A few solitary species, such as the red bat, roost in trees. In winter, bats either hibernate or migrate to warmer areas.
Posted on May 16, 2019
pramey3
    New Friend:
  • 22 Answers
It depends on where you are located. There are more than 1,300 species of bats, the world’s only flying mammal. In warm areas bats do not hibernate. And some species prefer living in manmade structures. Please visit www.batcon.org for more information.
Dale Brandt
    Habit-Forming:
    New Friend:
  • 83 Answers
In caves. Dark places.
Posted on Oct 31, 2017
NOEL
    Top Expert:
  • Miscellaneous Master
  • 8,546 Answers
In summer, female bats form maternity roosts while in winter, bats use hibernation roosts. Learn more about a year in the life of a bat. Most bats in the UK evolved to live in trees and caves, but many have now adapted to roost in buildings including barns, houses, tunnels and bridges.
Where Do Bats Live? - Bat Conservation Trust.
Were do bats live Google Search
I want to block a number on my cell phone with h2o wireless
1) Grab a baseball bat
2) find out where caller lives
3) show up in the dead of night after calling 911 to a fake dispatch location far away
4) beat the tar outta the caller and take their phone and beat the tar out of it
5) dump baseball bat in a random dumpster at least 2 miles away
6) Vote +1 for a successful block
Dec 04, 2011 | Cell Phones
I am trying to wire this device as illustrated on the back of the blister pack card and my breaker keeps tripping. Help !!!!!
You are switching from live to ground. Try connecting between live and the unit you are switching.
Jun 01, 2011 | COOPER WIRING DEVICES 452-BOX...
My blackbird has a new reg & bat and on my meter is charging ok..but the bat goes flat why
HI, FIRST THING TO CHECK IS, DOES THE BATTERY LOSES CHARGE WHEN IT IS DISCONECTED FROM THE BIKE, NOT THAT UNUSUAL TO HAVE A FAULTY BATTERY.
SECONDLY WHEN REPLACING THE BATTERY WITH THE KEY TURNED OFF DO YOU HAVE ANY SIGN OF DRAIN IN RESPECT OF A SPARK AT THE LEADS WHEN YOU TOUCH THE LIVE OR EARTH TO THE BATTERY POLE, THIS WOULD INDICATE A DRAIN
Dec 24, 2010 | 1999 Honda CBR 1100 XX Super blackbird
Drained battery
you may have damaged the battery and may need a new 1 and also check the wireing on the dash board as the perminant live which is the yellow wire could be connected to the live which is the red wire on the radio which keeps the radio on even if the keys are out the ignition
Jul 05, 2009 | Panasonic CQ-C7301U CD Player
1999 breeze, no power to the fuel pump and the fuel pump relay seems ok, I wonder what to check next?
THERE IS A SHORT ON YOUR LIVE WIRE,THE EASIAST IS TO GET IT TO A MECHANIC,BUT IF YOU WANNA DO IT URSELF TAKE A TESTER AND TEST THE POWER AND EARTH CABLES FOR LIVE THEN TAKE A LIVE WIRE FROM THE BAT AND CONNECT IT DIRECT TO THE FUEL PUMP WITH A FUSE ON AND TEST,IF THAT SORTS THE PROBLEM OUT GET IT TO A AUTO ELECTRICIAN TO WIRE IT UP CORRECTLY OTHERWISE YOU MIGHT BURN OUT SOMETHING,ALSO HAVE YOU CHECKED ON YOUR POINTS AND CONDENSOR.
Jul 04, 2009 | 1999 Plymouth Breeze
Plasma 42" daewoo edtv black line down middle
Attempting the solder fix is a big undertaking, gaining access to the components is a MAJOR undertaking, and probably not worth your while.
If it is simply one line you might try the baseball Bat fix....
In reference to the "basebal Bat fix" it works on occasion by using percussive force to realign the ribbon cables.
DO NOT use a baseball bat, but use a rubber mallet and with the power off tap gently directly above and below the offending line.
Its worth doing this if yo cannot live with the line.
If you can live with it, leave well enough alone!
Oct 14, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Battery drain
Go to http://www.partstore.com and put in your information. $42.00 plus shipping. Hope this helps.
May 30, 2006 | Sony Walkman MZ-R50 Personal MiniDisc...
Miscellaneous Logo
Top Miscellaneous Experts
William Miller
William Miller
James Cagle
James Cagle
Joyce Craven-yost
Joyce Craven-yost
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
