Music Logo
Y
YEMI ODUNSI Posted on Oct 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook up my Alesis Microverb III effect to Mackie CR1604VLZ and allow maximum aux sends for monitors ?
Ben Armstrong
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Oct 31, 2017
Ben Armstrong
Expert
Level 2:
Sergeant:
Answers
360
Questions
Helped
95461
Points
788
What you need to do is connect (for example" Aux 1 send from the desk to the Left Input of the alesis. Then connect the Left and right output form the Alesis to Auxilery return 1 and 2. You can just use the left ouput and use aux return 1 if having mono effects is ok.
2 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Feb 19, 2010
SOURCE: Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Anonymous
  • Posted on Mar 01, 2012
SOURCE: monitor mix of x2442usb
Hi Mark, I mailed Behringer and they sent me details of how to do it. If you mail me at [email protected] I'll forward it on to you. It looks really complicated to get a stereo signal through but I just use mono signal and its simple and works really well
How do I connect Aleis gt with alesis q2
Those units are both made to go in the effects loop of an amplifier, you would want to hook your effects send to the input of one unit, then the output of that to the input of the second unit, and the final output into the effects return of your amplifier
How do i hook up monitors to mackie1604 vlz pro to where you can hear music and mike.
Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
I use 5 out of 6 aux. for monitor...That leaves only 1 aux. for delay/reverb. is there another way to hook up delay/reverb to mixer?...SR24-4 mackie mixer...
Why are you not using the inserts? Either assign a sub channel to your effects unit or do it at a channel level. In either case using the insert.
It sounds like you're new to 'professional' mixers. You would NEVER normally use an aux for effects. Any effects will normally be inserted in the sound chain using an insert. You have a pair of group inserts if you are wanting to apply an effect to the output (these are after the mix) and would typically be used for master de-essers or possibly compressor limiters or maybe even an equaliser, it would not be sensible to use an effect like a delay/reverb here.
I would have expected you to be using the group outs for the monitor mixes and am not sure what you may be using them for otherwise. If you used these you would free up 4 of the Aux outs for a 'multi channel' reverb/echos which you could take back into other channels and back into the main mix.
What is it you are tyring to achieve?
1helpful
The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
I am trying to run a monitor using the Aux Send on a Mackie Board but even with the Master Aux Send turned up there is barely any sound coming out when I try to use my microphones. Also, I noticed that...
No there is no special cord. The aux you use for a monitor should be pre fader( that means the signal comes before the volume slider) turn the individual slider all the way down. Talk into the mike at the volume you would be singing at the loudest. Adjust the gain of that chanel up untill the clip light comes on. Now back it down so it dosent come on at your loudest. Now pick the aux you want to use. Turn it up 1/2 way, turn up the master aux send coresponding to the channel aux number 1/2 way you should get sound. If it's too loud turn it down if you need more turn it up. If you have any more questions, give me a call at the shop.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
[email protected]
[email protected]
www.prolinemusic.com
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
I have a mackie 24 channel mixer , I am trying to hook up my monitors. I need help I don't know how to do it. Recently lost our sound tech guy here at the church.
Decide if you want to use the AUX's or the SUB's for your monitors. (usually use the AUX).
Connect TRS cables from the appropriate AUX sends to thee amplifiers you use for your monitors or your powered monitors whichever you have.
Adjust the level using the AUX level controls for each channel to set your minitor mix.
Normally use the PreFader AUX's so monitor levels are set independent of the slide fader positions.
Here is a big hint for you: Search YouTube.com for "Soundboard" or "Soundboard setup". There are good videos there that might be different than your particular board, but there is enough commonality that you will soon be an expert!
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
