Question about Verizon Cell Phones
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Posted by Rock Aduh on
  • Daryl Limbanganon
    Daryl Limbanganon Oct 31, 2017
    Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
    1. Ensure the device is powered off.
    Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
    2. Press and hold the Volume Up/Down buttons then press the Power button.
    Note When presented with the Boot Mode Selection Menu, release all buttons.
    3. Press the Volume Down button to tap Recovery then press the Volume Up button.
    4. From the DROID triage screen:
    a. Press and hold the Volume Down button.
    b. Press and release the Volume Up button.
    c. Release the Volume Down button.
    5. Select wipe data or Factory Reset.
    Note Utilize the volume keys to highlight and the Power button to select.
    7. Select Yes -- delete all user data.
    Note Data wipe may take several moments.
    8. Select reboot system now.
    Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
    Hope this helps.
Daryl Limbanganon
    Habit-Forming:
    New Friend:
  • 37 Answers
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Posted on Oct 31, 2017
Marvin
    Top Expert:
  • Verizon Master
  • 85,239 Answers
Turn off the phone
5 Related Answers
micromaster
micromaster
  • 3614 Answers
SOURCE: lost password for moto ming a1200
Did you never change the password before..? & i want to know what exactly, it is a security code or a sim security code
Posted on Jun 03, 2008
James Ely
  • 199 Answers
SOURCE: moto q
I believe the Moto Q can support this so the basic flash you received only hacks the SPC, changes it to null value and writes the PRL (preferred roaming list) for Cricket and it's partner carrier's towers. Then, assuming it has not been reported lost or stolen, they will add your ESN (electronic serial number) or IMEI (international mobile equipment ID) so you can make and recieve calls. This does not enable picture messaging or internet. This is a separate procedure using computer software and there are several things which need to be changed in the firmware like your MID (mobile identification number) web addresses, protocols, and passwords for Cricket mobile service. You will need to take it to the person who flashed your Verizon and ask for the full flash so you can get the internet. I hope this helps. If you already paid for the full flash ask them to redo it and test it before you leave the store.
Posted on Jul 13, 2009
Anonymous
  • 8 Answers
SOURCE: Need password unlock code for HP Pavilion dv5
You can start it in safe mode pressing the F8 key...it change between brands but must out there use f8... when you start in "safe mode" in the log in screen you will find your user name and the administrator one...normally the administrator don't have password, so you can log into it and there you have the permission to delete other users passwords...
If you don't found that option, there is an other option but you need to download it and burn it in a cd... Is called ERD Commander here is the link for it: http://rapidshare.com/files/113560492/ERD.Commander.2008.CrOwN.rar... the password for decompress it is:( munda ) when you have burned it, insert it in you cd drive> go to your computer bios>select boot priority>change it for boot from cd first...once you have done that press f10 and select the option yes to save your settings and restart your pc....then your computer will start with a wizard looking like windows xp...complete all the things that it request...when finally boots up>go to start menua and select system tools>locksmith and delete all the passwords that you want...that's it! restart without the cd in the drive and log in! "Hope it works for you"
Posted on Jul 20, 2009
Anonymous
SOURCE: My brother in-law pass away, no one know the
Remove the silver trim ring carefully using a small screwdriver. After you remove this, you will see a reset button on the right side. Push this in and it should clear the password.
Posted on Nov 03, 2009
Camelia Grapan
  • 49 Answers
SOURCE: I need a free unlock code for my verizon droid incredible phone. Can anyone help?
If it is an HTC Droid Incredible 2 you can unlock it as it is a dual mode CDMA/GSM phone. You can unlock your HTC Droid Incredible 2 from Verizon in order to work with any GSM network. You have the entire guide here:
http://www.htcimeiunlock.com/htc-blog/how-to-unlock-a-dual-mode-cdma-gsm-phone-2013-02-23/
Unfortunately i don't know a free unlock code source but the HTC unlock service i recommended to you is a trusted one, have small prices and good support. I use it also to unlock my HTC EVO Design 4G a dual CDMA/GSM also.
http://www.htcimeiunlock.com/htc-droid-incredible-2-unlock
Posted on Feb 25, 2013
Ok, lets try it this way I want to purchase a used android & turn it on using tracfone pre-paid servive. what brands of cell phone can I purchase?
http://tracfonereviewer.blogspot.com/p/tracfone-byop-phone-list.html
Tracfone BYOP 4G LTE GSM (AT&T) Phone List:
Samsung Galaxy S7 - various options on Amazon
Samsung Galaxy S6 - various options on Amazon
Samsung Galaxy S5 - 16 GB on Amazon and eBay
Samsung Galaxy S3 - 16 GB on eBay
LG G2 - 32 GB on eBay (refurbished currently $139)
LG G3 - 32 GB on Amazon and 32 GB on eBay (refurbished currently $189)
LG G4 - 32 GB on Amazon
Moto G 4th Gen (latest version) - 16 or 32GB on Amazon
Nexus 6p - 32, 64 or 128GB available on Amazon
Nexus 5x - 16 GB on Amazon
Motorola Moto X 4G LTE - 16 GB on Amazon
Motorola Moto G (1st gen) 4G LTE - 8 GB on Amazon
HTC 1X - 16 GB on Amazon
Blu Stdio 6.0 - 16 GB on Amazon
Asus ZenFone 2 - 16 GB on Amazon
BLU Studio C Super Camera - 8 GB on Amazon
iPhone 6 and 6 Plus - 64 GB iPhone 6 on Amazon - 64 GB iPhone 6 Plus on Amazon
iPhone 5s - 16 GB on Amazon
iPhone 5 - 16 GB on Amazon
iPhone 4/4s
Nokia Lumia 640 (Windows Phone)
And many more options, let us know in the comments what you are using!
Tracfone BYOP 3G and 4G LTE CDMA (Verizon) Phone List:
Motorola Moto G (4th Gen) 16 or 32 GB on Amazon
iPhone 6 - 16GB on Amazon (64GB and 128GB also available)
iPhone 6 Plus - 16GB on Amazon (64GB and 128GB also available)
iPhone 5 - 16GB on Amazon
Samsung Galaxy S5 - 16GB on Amazon
Samsung Galaxy S4
Samsung Galaxy Note II - 16GB on Amazon
Samsung Galaxy Note III
LG G2 - 32 GB on Amazon
LG Lucid
Nexus 6 - 32GB on Amazon
Nexus 6p - 32, 64 or 128 GB available on Amazon
Nexus 5x
Moto X 2013 Edition - Amazon
Motorola Droid Razr M
iPhone 4 - 8GB or 16GB - Find on Amazon and eBay
iPhone 4S - 16GB or 32GB - Find on Amazon and eBay
Motorola Droid 1
Motorola Droid 2 - Find on Amazon
Motorola Droid 3 - Find on Amazon and eBay
Motorola Droid X
Motorola Droid X2 - Find on Amazon and eBay
HTC Droid Incredible - Find on Amazon and eBay
HTC Droid Incredible 2 - Find on eBay
Samsung Fascinate - Find on Amazon
HTC Rhyme - Find on Amazon
HTC Trophy (windows phone) - Find on Amazon
HTC One M8 (windows phone)
Moto G - Find on Amazon and eBay (we have one report suggesting a user got a used Verizon Moto G that had been active on Verizon prepaid for 6 months, and was able to activate with Tracfone, more feedback appreciated!)
Jan 08, 2017 | Android Cell Phones
What battery do i need
The battery that you need for your Droid X is the one show in this link.
My Moto
If you want the regular battery and not the extended battery the model number is BH5X.
Hope this helps.
Jun 23, 2014 | Motorola Mobility M8810 Droid X Verizon...
My motorola android droid x2 wont get past welcom push android character how can i by pass to get to apps
Tap the upper left, upper right, lower right, lower left, (clockwise) to by pass activation.
Feb 21, 2014 | Motorola Mobility DROID X2 Android Phone...
Feb 24, 2013 | HTC Droid Incredible Verizon Wireless
MY DROID HAS NO SIM CARD HOW CAN I USE IT AS A CELL PHONE
In USA, Verizon offers Droid which uses CDMA technology. You can call Verizon customer service and tell them to activate the phone on your account. You should be a Verizon customer, should have a data plan and the phone serial number should be clean(not in lost/stolen list and active on another account). You'll have to give ESN number to the Verizon customer service agent while calling them. ESN number is at the back of the phone when you take the battery out.
Mar 15, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I need a code to connect to the internet and I don't know what the code is or how to get it. Please help.
If you have a Motorola Droid, I'm assuming you're with Verizon. If you're with Verizon, the only instance where I could see you needing a code is if you have setup your Google account with their new 2-step account verification system. If that's the case, you'll need to log into your Google account online, https://www.google.com/accounts/ManageAccount, click on "Using 2-step verification", then click on "manage application specific passwords". There you'll create a password just for your Droid.
Feb 20, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Need to unlock motorola droid to work with my att acc i know it can be done
If this is a phone that is not branded by your service provider (example: it's a verizon phone and your trying to use it with att) you first need to make sure that it is compatible w/ att network. The phone needs to be able to take a sim card. Second, you would need to get an unlock code from the provider that the phone originally came from. Once you have that they will inform you how to unlock the phone and you will be able to use it on the other network. Be aware that since the phone is actually made for the other network that it may not work properly. This is because the phone is designed to work on a different network and will have different settings, therefore it is not guranteed that it will work to it's full capabilities, especially the internet.
Mar 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My phone locked itself, and I don't know the password
try 0000 or 1234 in most cases these 2 common passwords work
Jul 30, 2009 | LG Shine (CU720) Cell Phone
Cell Phones Logo
37 people viewed this question
Top Verizon Cell Phones Experts
ChinthakaJ
ChinthakaJ
john h
Andrew Taylor
Andrew Taylor
Are you a Verizon Cell Phone Expert? Answer questions, earn points and help others
