Question about Vision Televison & Video
I need plan number for vision - Vision Televison & Video
Posted by Michael Inghram on
Larry
  • Vision Master
  • 2,800 Answers
What are you asking?
Posted on Oct 31, 2017
What is field of view in Binoculars, Spotting Scopes and Rifle Scopes?
Optical field of view (FOV) refers to the width of the area that you can see when looking through a pair of Binoculars or a Spotting Scope, quite simply, how wide an area you can see through your optics. Field of view is usually described in terms of 'linear field of view' or 'angular field of view'. Both figures essentially indicate that the field of view of the optic is a certain width, but they just use different numbers to describe this.
Linear field of view is also known as the true field of view and indicates the width (in m) of the area that you can see when standing 1,000m away from an object.
Angular field of view is also known as the apparent field of view and refers to the true angle (in degrees) seen through the optics.
It is easy to convert between the two field of vision measurements:
To convert an angular field of vision to a linear field of vision, simply multiply the angular field of vision by 52.5.
To convert a linear field of vision to an angular field of vision, simply divide the liner field of vision by 52.5.
When choosing your binoculars or spotting scope, take some time to consider where you are planning to use them, as this will indicate the most suitable field of view required to get the most out of your product. The most important thing to remember is that the larger the number is given to the field of view (FOV), the larger the width of the area you will be able to see through your scope. A larger field of view is desirable if you are planning to use your scope to watch anything that is moving quickly across your viewing area as it will make it easier to aim and stay on a moving subject. For this reason, scopes with a larger field of view are favored by people watching birds in flight, a ball at a cricket game, an athlete in a race or views from a moving car.
Don't forget field of view (FOV) and magnification are closely linked, with higher magnifications resulting in a smaller field of view. Take some time to consider whether you wish to view your subject in great detail, or would prefer to be able to keep track of it if it is moving quickly; after all, there's no point being able to see the fine detail on a bird's feather if you can't find the bird in the first place!
Mar 21, 2018 | Optics
I am in need of drivers that will allow me to use my Visioneer 8920 USB scanner in a Windows 7 OS. Any help is really appreciated!
I'm afraid that won't happen. Visioneer's drivers are only good through XP Service Pack 1; they won't even support XP Service Pack 2 due to the increase in security measures. There is no Windows 7 driver (or Vista, for that matter) and they don't plan on developing/releasing one as the product is discontinued.
Sorry...but hope that was helpful.
Jan 16, 2011 | Visioneer OneTouch 8920 Flatbed Scanner
I need to know where the fuel pump is located on a 1994 eagle vision tsi
The fuel pump on your vehicle is located in the gas tank! I believe there is an access hole from the trunk. The hole has a plate over it. Remove the plate, and follow directions to remove pump.
Recommendation: Repair manuals are always the first "tool" to get when you're planning on working on your vehicle.
If this info was helpful, please post... Thanks...
Jun 27, 2009 | 1994 Eagle Vision
Antifreeze dripping off front of block on 1993 Eagle Vision
when the water pump starts to fail it leaks out of the weep hole that is built in as a warning . plan to replace it soon.(obviously check simple stuff first- hoses, clamps...0
Jan 20, 2009 | 1993 Eagle Vision
Ford focus 2002
The replacement bulb for the headlight in you Focus is a 9003. There are several variations to this number though. For example GE/Sylvania has a 9003CB--CB standing for "Cool Blue", 9003XV--XV standing for Xtra Vision, etc. Hopefully you plan on replacing both bulbs when you go to do so. You lights will not look like you have one old bulb and one new bulb and you won't have to worry about it going out on you at a bad time and costing you a traffic ticket. Hope this helps and have a great day!
Nov 23, 2008 | 2002 Ford SVT Focus
Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Jul 06, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
SCANNER
"download"?? You don't download, you install. Have you considered that the scanner might not be compatible with Vista? Here's the Visioneer site: http://support.visioneer.com/products/home/EOL/8100/downloads.asp
Jun 22, 2007 | Visioneer OneTouch 8100 Flatbed Scanner
Televison & Video Logo
23 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
