Question about LG Televison & Video
My LG 42LH5000 TV is not turning on. A few days ago suddenly switched off and now it doesn't turn on. The red LED is always on. If I unplug it turns off and when I plug again the LED is red again.
If I click the ON/OFF button nothing happens. I have opened the TV. A visual inspection doesn't who anything broken or burnt. I have pictures. The TV is from October 2009.
Posted by Borja Guardiola on
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
I had the same problem with Samsung. A web search located the issue being the capacitor. Take out the back and look for the capacitor near where the power line enter the TV. It was a 100 uF at 4050 volts capacitor. checked the DC voltage to be 381 volts. Got two old capacitor from an old TV - one was 150 uF at 400 volts and one was 220 uf at 400 volts. It turned out that it needs two in parallel (making 370 uf at 400 volts. Took out the under rated 100 uf and replaced it with these two. Checked the voltage to be 390 volts. That did the job. Samsung must have tried to save money by putting in a 100 uf at 450 volts. .
Posted on Oct 30, 2017
Testimonial: "Thanks for the suggestion. After opening the TV I don't see any burnt or damaged capacitor. Any idea?"
  • Borja Guardiola
    Borja Guardiola Oct 30, 2017
  • Sometime Mechanic Oct 30, 2017
    There are three separate boards: input, power, and video. The power board has the 120 volts and very near the power line is the capacitor. (Some TVs have more than one capacitors.) It was not burned, just no creating high voltage. Measure the high voltage across the capacitors, should be close to 400 volts DC. If it is around 380, it is low. The problem was looking for another capacitor with a high working voltage and uf rating.
5 Related Answers
Anonymous
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
ABRsvcs
  • 4234 Answers
SOURCE: Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Posted on Aug 25, 2008
Anonymous
  • 106 Answers
SOURCE: Panasonic TH-42PX80U won't turn on.
You are missing 15volts. If this is a new TV, it could be as simple as a plug not fully seated on the power supply. Regardless, the repair should be covered by warranty and Panasonic is one of the best when it comes to taking care of the customer. Ifd nI can be of further assistance, let me know
Posted on Dec 21, 2008
Anonymous
Heat the bridge rectifier with a blow dryer and see it turn right on.
Posted on Sep 13, 2009
Anonymous
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Jan 28, 2009 | Televison & Video
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
LG 50PC55 Plasma - Wont work?!?
I had an issue with this TV too, it suddenly started blinking on and off whilst I was watching TV. I turned it off and on and problem persisted. I then pulled the power cable out from TV whilst it was still switched on and waited a few mins and put it back in. It has been 2 days and the issue hasn't happened again.
Oct 12, 2007 | Computers & Internet
Televison & Video Logo
Raj Patel
