SOURCE: Microwave Turns on automatically
I would remove the plug from the mains for at least one hour. This should remove any memory
SOURCE: oven won't heat and shuts down after approx. 20 seconds
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Microwave Oven Does Not Start Cooking
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
SOURCE: oven won't function after 5 minutes of cook time with nothing in
It's posible that since it was running empty, the magnetron overheated
and a thermal cutout or thermostat located on the magnetron opened.
Magnetrons may be protected by a thermostat, which will reset when it cools, or a
thermal fuse, which is a one-time use device. It is also possible that
in some cases, a thermostat will fail when opened.
In the worst case the magnetron may be damaged due to running empty.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
