Question about Blaupunkt Televison & Video
My TV Blaupunkt tv has turned itself off this morning after a few seconds, and there is no red light on the TV now
Posted by Susan Harvey on
Brandon Murphy
    Sergeant:
  • 214 Answers
It sounds to me that you no longer have standby voltage. If you are good with a multimeter, I would measure voltages on your power supply, check the fuse, and see if there are any burned components or bulging capacitors. Also check that you have your right voltage from the wall. Trying an outlet you know that works would be good if you don't have a multimeter.
Posted on Oct 30, 2017
5 Related Answers
SOURCE: tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Posted on Jul 15, 2007
Anonymous
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
Anonymous
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
Anonymous
  • 814 Answers
SOURCE: Samsung TV Turns off after a few seconds red and green light flas
You are going to have to troubleshoot all the boards in the television until you find the problem. Start with power supply board. This part usually goes bad due to overheating and faulty components. You must check for brown spots on the boards , that are signs of overheating. Look for bad components like bulging capacitors and burnt resistors.Look for bad connections, like cold solder joints. you must be very careful working on the power supply board as it does have high voltages they can be very dangerous to the inexperienced user. Never test anything with the power on or connected.Use anti static protection straps and gloves around all the chips and microprocessors to avoid damaging them. Check all the other boards for the same problems. If you can find no problems, Then it is time to get help from a service center where they will have all the necessary testing equipment, To give the unit a more thorough testing for faulty components.Hope this helps you with your problem.
Posted on May 17, 2009
Anonymous
  • 92 Answers
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
Posted on Sep 07, 2009
Flashing red light on VIERA TV
you need to count the blinks of the light. it will determine where the problem is located.2_25_2013_1_43_46_am.jpg
Feb 24, 2013 | Panasonic Viera TH-42PX80U Plasma TV
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
TV turns itself off after being on a few seconds, ...
Three time blink means tv got problem in convergence output circuit, replace convergence output ICs to solve the issue.
Thanks.
May 21, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Televison & Video Logo
895 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
