Question about Ricoh Office Equipment & Supplies
What defines sc-556 on ricoh 212snw machine - Ricoh Office Equipment & Supplies
Posted by Kiran Jadhav on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
Fuser Unit Error
Posted on Jun 26, 2018
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
Anonymous
  • 126 Answers
SOURCE: machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Posted on Jan 20, 2009
Anonymous
SOURCE: error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Posted on Feb 24, 2009
Anonymous
  • 170 Answers
SOURCE: sc 556 for ricoh aficio
check the fusing unit thermistor,thermoswitch &heaterlamp
Posted on Nov 22, 2010
Anonymous
SOURCE: Ricoh Aficio MP 2000Le Machine error code SC 546 appears.
"Unstable Fusing Temperature" Chang Fusing Thermistor.
Posted on Jan 07, 2013
How to resove service code sc556 in sp210su in recoh printer
ressure roller fusing lamp temperature fluctuation The pressure roller temperature changes by ±20°C or more in one second. This occurs three times in one minute or two consecutive times.
Causes
• Loose connection of the pressure roller thermistor • Loose connection between the fusing unit and main frame
Remedy
1. Check if the fusing unit is properly set and connected to the main frame. 2. Check if the pressure roller thermistor connector is firmly connected. 3. Replace the fusing unit.
Ricoh Aficio AP3850C Error Codes
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/34525-ricoh-aficio-cl7000-sc-556-error-code.html
My machine ricoh aficio keeps on showing error code sc 556 and it cant print but keeps on telling me paper out
1) If the printer continuously displays the error code SC556, try these solutions to resolve the issue. Check if resetting the printer resolves the problem.
2) Power on the printer by pressing the Power button and then unplug the power cord from the printer's rear. The power cord should be unplugged from the wall outlet and wait for at least 15 minutes.
3) Connect the power cord back to the printer and the wall outlet and check if the printer turns on. If not, press the Power button on the printer.
4) See if the printer still displays the error message on the control panel screen. Try to reload the paper and check the condition of the paper.
5) Try to adjust the paper settings in the print driver and see if the issue is resolved.
Ricoh sp 210su printer error sc 556 any solution
To resolve this error do soft reset your printer by switching it off and disconnect all the power cables.
Now after printer settle down press and hold power button for 60 seconds after that use 2nd method.
Remove back cover of the printer.
remove print head and cartridge.
Remove rollers on the printer and clean them.
Refix alll of them and restart printer.
For more info : http://bit.ly/2FfFKr7
Ricoh mp 2000 erreur sc:556
Thermistor defective or out of
position (replace thermistor)
2answers
Printer Ricoh sp 210SU "service call error SC491". using compatable cartridge instead of Ricoh original. Service centre suggests to change the cartridge to solve the issue. any idea else pl share me
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Sc 556 for ricoh aficio 2018
What is the sulution for e541 copier machine ricoh 5832
SC 541 indicates a problem with the heating unit thermistor in the machine.
This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
2helpful
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
times.
the pressure roller
thermistor 1. Check if the fusing unit is properly set
• Loose connection 2. Check if the pressure roller thermistor
between the fusing
unit and main frame
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
