Question about MTX Car Audio & Video
What type of amp do i requier for my mtx tt6510-2 10 inch subwoofer
Posted by Adolf Hemmerling on
5 Related Answers
Anonymous
SOURCE: 4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Posted on Mar 09, 2008
Robert marquette
  • 102 Answers
SOURCE: need proper wiring details.
This is a dual 4 ohm sub. By wiring the terminals in series (one set of + to - from one side to the other) you will have an 8 ohm sub (most folks probably don't want this). By wiring in parallel (+ to + and - to - and connect the - wire to the - terminal on your amp and the + wire to the + terminal on your amp you'll have a 2 ohm sub.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Mar 12, 2009
Anonymous
  • 152 Answers
SOURCE: i have two 15 inch L7 Solo-Baric Subwoofers and need an amp
I would recommend a brand named class D amplifier.
Connect both woofers in parallel (Positive to positive, and negetive to negetive) in a sealed enclosure. Make sure you have no air leaks. By connecting them in parallel the combined impedance will be two ohms. Make sure that the amplifier you choose can handle a load with that low of a resistance. Any high end amp should do this. Buy as much power as you can, but I would say a minimum of 1000W RMS. Beware of cheaper amps advertising "peak power". This can be considered half of what the RMS power would be (1200W peak = 600W RMS approximately).
Next, Run very heavy gauge (zero guage if you can) power line directly from the battery. Protect the wire where it passes through the body with a rubber grommet or otherwise something to keep the metal from cutting into it, and PUT A FUSE IN. I cant stress that enough. Put an 80 amp fuse in line incase you have an accident. Otherwise your car could very well burn!
Want even more punch?
Back at the amp, install the largest stiffener capacitor you can afford 1 Farad or bigger. Install this in a space where it would be protected in the event of an accident (on the inside of the strut tower or somewhere above the axle). There is a whole lot of energy stored in there that you don't want unleashed on you!
If you have any other questions please ask away!
Posted on Apr 13, 2009
Anonymous
  • 11 Answers
SOURCE: just hooked up mtx 500d mono amp and 12 inch sub
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
Posted on May 17, 2010
Lissa Wied
  • 344 Answers
SOURCE: how many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Posted on Nov 28, 2012
How many watts will the 10 inch mtx thunder 4000 have
2answers
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Why does my MTX SW1515 subwoofer make a repeating thud when i turn it on? and can i fix the problem
When a subwoofer first notices a signal on the incoming line, this causes the amp to kick on which can result in some initial "noise" as the amp powers up.
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
I need to know the deminsions to build a box for my rfl mtx 15
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 16 inches x 16 inches x 16 inches
Wiggle the positive wire to get power and have to unplug subs to turn car off
Ok it sounds to me that your remote wire is not hooked up right casue if you trun your car off then your amp should power down an when you trun your car on it should power up
2answers
Picking the right amp.
yes you could go with a 2 channel. You could alwayse bridge it.
I have 2 8ohm 10" speakers an 2 4 ohm how can i wire them
i need more info on the type of amp u want to use / do u have one amp or to amps that u are trying to use?
Car Audio & Video Logo
Top MTX Car Audio & Video Experts
Pierre Laplante
Steve Sweetleaf
Steve Sweetleaf
 Francisco Mauricio...
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
