Question about Kwikset Locks & Locksmithing
Does kwikset 913 have lighted numbers for night? How do you cut on lighted numbers?
Posted by James Dean on
Does lockwood and kwikset use the same keys
The popular Kwikset keyway is used by many companies, and will fit into one of Lockwood's keyways. The spacing is a little different, so if you are trying to make locks of both brands work with the same key, double check the width of the cuts while you have the locks apart to make sure the pins you are using will sit on the bottoms of the cuts and not on the slopes of the sides of the cuts.
If you just want to copy a key, then there won't be a problem. Lockwood does have 6 and even 7 pin locks, so make sure your key is the right length.
Oct 28, 2013 | Kwikset Locks & Locksmithing
Green light keeps blinking even after changing batteries
I can't help you directly, but I can direct you to Kwikset's customer service contacts. I'm sure they can assist you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
There is an 800 number to call listed here.
Jul 21, 2011 | Kwikset 909 909-L03 Lifetime Polished...
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Feb 04, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
My numbers on the keypad are worn off of my Kwikset Powerbolt lock where can I buy replacement numbers
Contact Kwikset Customer support:
http://www.kwikset.com/Customer-Support/Overview.aspx
good luck!
Jan 12, 2011 | Kwikset UltraMax Powerbolt 1000
The light continues to blink
LED light goes red (not blinking, just stays red) and none of the buttons on the lock work.
My reply:
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Good luck--and please provide feedback if this helps!
Jan 08, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Why doesn't the back lights work on my Kwikset 907 Power 1000 Keyless Entry Deadbolt? Are there any other batteries beside the four 1.5 alkaline batteries?
Installation instructions for the Kwikset 907 link:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Oct 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I lost the battery cradle. How can get another cradle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1-800-677-5625
Kwikset manual invites people to call phone number or visit website
http://www.kwikset.com/smartseries/smartcode.aspx
Oct 20, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
The key pad does not light up at night
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Oct 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I installed the Kwikset 907 model last night and it was working fine. Tested it several times, showed the family, etc...Everything worked great. My son left for 10 minutes and came home and it no longer...
Why is my Powerbolt beeping?
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Oct 11, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
I installed this last night and it was working fine. Tested it several times, showed the family, etc...Everything worked great. My son left for 10 minutes and came home and it no longer worked. The keypad...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Locks & Locksmithing Logo
369 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Marvin
Marvin
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
