Refrigerators Logo
P
Pam Bertheim Posted on Oct 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the drain plug in my Amana freezer Took basket out and not there
Terry
Level 3:
  • Amana Master 11,377 Answers
  • Posted on Oct 29, 2017
Terry
Amana Master
Level 3:
Answers
11377
Questions
Helped
4626185
Points
152765
There is a fixya answer for the Amana upright freezer although I am unsure if that is your model or not:
Where is the drain plug on the Amana upright freezer How do get to it to...
2 Related Answers
Anonymous
  • 145 Answers
  • Posted on Apr 18, 2008
SOURCE: Freezer lower basket: how to get a replacement part not available in Canada
I can't find a cross reference that shows avalible. The lower basket part number is 67001240. I would try a web search for that number some still has it in stock somewhere.
Anonymous
  • Posted on Aug 04, 2008
SOURCE: FRS23R4A Side by side
Will ice maker work without filter
I have an Amana refrigerator model # ARB2217CSR with the freezer on the bottom its filling the the freezer with water and leaking on the floor even with the ice maker water supply off can someone help...
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Water in bottom of freezer
most likely you have a plugged drain. pull panel in freezer if ice in drain pan then drain is plugged melt with hair dryer
2answers
Amana abb222zde bottom freezer not defrosting
unplug the freezer. let it defrost for a day then plug it back in. You will be fixed up then.
4helpful
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
2answers
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
2answers
The answer to your question is yes. You can access the drain from the back of the freezer. In most cases there is a seal loop that sometimes plugs up. You will see the hose going into the drain pan under the unit. I use a piece of speedometer cable as a mini rotorooter.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
