Hi I have a new ge refrigerator model number GTS18GTHWW amd it did not come with an ice maker. I installed new ice maker and water valve. But nothing it seems like there is no power going to the ice maker at all.
Replace the control board. It is not supplying power to the icemaker.
GE WR55X10942P Electronic Board PartSelect
SOURCE: Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
SOURCE: user manual for GE Ice Cream Maker Model 106765
Hi
Thanks for using FixYa. You can download the user manual for GE Ice Cream Maker Model 106765 from the following link—
GE Ice Cream Maker Model 106765 User Manual
Please do rate the solution.
Thanks
Rylee
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A
service call is approx $80. The $80 will be deducted from the
part/labor if you choose to purchase/install parts from the service
technician. If not, you will pay for the service call. Good luck.
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
