Cameras Logo
Question about Canon Cameras
I have a canon x60 powershot, and it has started to over expose my still shots, the video still works fine. Ive tried reset but still not working
Posted by Bamboo22 on
5 Related Answers
Anonymous
SOURCE: Canon Powershot S5IS Aperture
To get a narrow DOF with the 5S you have two choices: Shot from up close with macro mode or shot from far away with the zoom. Of course you also need to select a wide appearture (under 4).
At a normal 35-80mm equivalent, in most situations it is impossible to get a decently shallow DOF with this camera.
Posted on May 15, 2008
Anonymous
SOURCE: Canon Powershot A570IS Problem
Try to use the Auto mod.
Posted on Aug 30, 2008
Anonymous
SOURCE: Remote shooting with my canon powershot A560 can i do it?
According to Canon, only some of the A series Powershots are compatible with this function. See...
< http://www.usa.canon.com/consumer/controller?act=SDKHomePageAct&keycode=Sdk_Lic&fcategoryid=314&modelid=7474&id=3464#SDKQ7 >
The A580 is not one of them.
Posted on Sep 20, 2008
junfeliciano
  • 4 Answers
SOURCE: Canon Powershot Pro1
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Posted on Nov 27, 2008
t00nz
CameraR
  • 4738 Answers
SOURCE: Canon S400 Pictures are over-exposed with horizontal lines-LCD ok
For both of you, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 28, 2008
How do you fix a canon power shot A70 whose ccd has been exposed to sunlight? My screen is blank. Will not focus on anything..
If the sensor has been exposed to the sun for a period of time unfortunately it will mean a new camera. I believe the price to replace a sensor is pretty close to getting a new camera.
15helpful
4answers
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
5helpful
White photos canon A470? i have a canon powershot A470 camera and there's a problem taking photo.. whenever i take a picture, it's either fully white or have white stripes on the pictures.. i thought it...
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
Ive got a canon powershot a560. I recored a 15 minute video and took some photos. The photos have transfered to the pc but the video wont budge. It cant be copied. Ive tried using the advanced settings on...
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see this article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your videos and photos.
Over exposed outdoor shoots
thanks, had same problem didn't know about video mode .I have the same problem if you get an answer please let me know
Canon 10D works fine after impact but overexposes now.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
3helpful
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Lines across view screen & on pictures; looks like interferance.
If your camera is Canon A85, then it has problem of bad CCD Imager Sensor this part will be replaced.
Please go to Canon CCD Advisory and see details if you want to have free of cost repair from Canon.
Regards,
3answers
Over exposure
Hey - have the same problem. All my still pictures are coming out overexposed, no matter what setting I use. Tried resetting, tried new battery, tried new memory card, tried different exposure settings. Nothing fixed it or affected it. However, my movie exposure works great so I can take movies just fine. Are you able to take movies with no overexposure?
1helpful
3answers
Cannot find out where I can get the advanced user guide (Adobe) for the Canon Powershot S5 IS
Please send me a copy of the advanced user guide for Canon Power shot S3 IS immediately.
Hemanth kUmar
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
