Question about Locks & Locksmithing
My brinks 4 combination lock is open and I don't know combination. help me
Posted by pamela self on
5 Related Answers
Anonymous
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
Anonymous
SOURCE: need to reset combination on brinks digital home safe model 5040
the Brinks Company has a phone number you can call to get instructions on sending them a letter for a combination. It is 1-800-832-5834
Posted on Feb 12, 2009
Anonymous
  • 291 Answers
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
Posted on Apr 30, 2009
Anonymous
SOURCE: I have the Brinks safe model 5054. We recently
my safe is lock and i dont have the combination but the key is
still in the lock. so what can i do to get in to the safe.
Posted on Nov 03, 2009
Anonymous
SOURCE: Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
Posted on Feb 17, 2010
Brinks front 4-way combination lock is locked in open position. Absoulutely NOTHING on the internet about this problem. Will never buy another Brinks lock again!!
you should keep buying brinks just buy a diffrint one because all brinks are made of hardend steel which is what they make the armored trucks out of and their bullet proof fire proof and most can withstand 500 pounds of force. my brinks can withstand 1000 pounds of force. plus you can send the lock to brinks and they will replace it free of charge. since your lock is defective they will replace it free of charge. i hope i helped.
Jun 23, 2014 | Brinks 185-50051-4 Front 4 Dial Resettable...
I have a 418-392 Brinks combination lock and don't have the combination
I have the same lock and a forgotten combo. Did you ever find out how to get it open and reset?
Jan 03, 2014 | Brinks 1-7/8 In. SS Dial Combination Lock
My brinks 4-dial combination padlock will not open
hi,
sometimes the dial rings slip on these locks and sometimes it is just the spring release is stuck. you can try and spray some lube down into the lock and let it sit for awhile,, try the combo again,, if that does not work then you might consider maybe replacing the lock with something newer and more reliable.
hope this helps,
chris...
Sep 25, 2012 | Brinks 4-Dial Combination Padlock
Master code for brinks padlock
the lock combination is not working anymore, I can not open the lock, how I can reset the new combination
Sep 04, 2012 | Brinks 1-1/2 In. Brass Combination...
Hi, I have a Brink's Safe model #5059. Actually it was my husbands and he just passed away. Unfortunately, I don't know where the key or the combination. I need to get a key to open this. Can you...
Brinks will not help you with this, but you should be able to get into the safe if you call a locksmith. Brinks use a really cheap lock tumbler on models similar to yours and it's easy to pick for a skilled locksmith. So easy, in fact, that you really won't want to use that safe again as it's really an unsafe...
You can watch an example of how easy it is by clicking here.
Jul 26, 2011 | Locks & Locksmithing
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Locks & Locksmithing Logo
333 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
