How can i change language from chiness to english in printer Hp laserjet P3005N ??
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
SOURCE: Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
SOURCE: On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: change language from English to Chinese on lg9100
Languages (Menu 9.2.5)
You can select the display language. When the
language option is set to Automatic, the language is
automatically selected according to the language of
the SIM card used. English will be set if the language
on the SIM card is not supported in the phone.
http://www.cellphones.ca/upload/manuals/lg-f9100-manual.pdf
hope this helps!!! good luck!!
Found below instructions - should work to change from chinese as well.
Your Brother machine's LCD can display information in English or Spanish. The default language is English.
To change the language on your Brother machine's LCD, follow these steps:
