Not sure if this link will help you out.
1. The easy way (5 mins)
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
SOURCE: Panisonic TV all locked up
Any other developments (or lack thereof) after our Live Chat?
Regards.
SOURCE: none of my inputs work
Are you using the same HDMI cable with each device? If so it might just be a bad cable. If this isn't the case it may be a system setting which needs to be changed or possibly something requiring tech support.
SOURCE: Inputs do not work after power outage
The set has three ways to reset---the tiny button on the front, A second is called a soft reset, and the third requires going into the tech Menu with a code via the remote.
Try the soft reset first and let me know if it helps.
With the set on hit: Menu, 1, 2, 3, and enter.
SD TECH
SOURCE: Sound is really quiet with inputs
Hello. Please be sure that you are plugging your iPod into the tape in, or play, and not into the record out, or record. If you have these reversed, you will greatly lower the signal level going to the amplifier.
Dave
SOURCE: when plugging antenna in 37: protron tv do I use analog input or digital input?
An antenna is analog. Try using the setup menu for the tv to choose analog input.
