Natural gas mains pressure water storage heater
SOURCE: Gas (LP) Valve/ Thermostat Adjustments
that is the flow to the pilot lite and no it is not supposed to be readjusted, if anything you should get the numbers off the gas valve and replace it, or depending on the age of the water heater get a new one,
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
SOURCE: Rheem G75-125 natural gas. Water
Suggested order of things.
1) Read manual troubleshoot and maintenance sections
Find same-similar manual at Rheem
http://www.rheem.com/products/commercial/water_heating/commercial_gas/
http://www.rheem.com/product.aspx?id=0697944D-D79A-40C1-BDEB-875E48200DD1
http://globalimageserver.com/fetchDocument.aspx?id=c0b73553-5f03-4a5e-8789-4732ffecdccf
Maintenance and troubleshoot sections might help solve problem.
Download manual to your computer as a resource.
2) Post question on pro water heater forum, and include details from manual, and link to manual, so pros don't have to search Rheem commercial water heater page to find manual.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Contact Rheem who will ask you for name of installer and servicing technician.
4) Call service technician.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: 7-25-11. Purchased Reliance 909 model
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
SOURCE: Pilot won't light on Rheem
Following information is for tank-type gas water heater:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
