Vg23ah, now that it is apart I dont see any bad caps or solder joints. does any one sell a RoHS 715G3727-P02-006-0035 board or is it cheaper to buy another monitor. I am getting very fine flickering horiz. lines across the screen. this has been a once in a while thing but now its all the time. The 450 cap in circuit reads 150mfd.actually the cap reads correctly. they all do. does anyone have any experence with this problem.
Please look at my pictures of failed monitors, read the guide to understand how monitors work, learn about bad caps, bad solder joints, etc. http://s807.photobucket.com/albums/yy352/budm/ACER%20AL2017%20Abd/ If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
It can be bad caps, transistors, cold solder joints, bad lamps, etc. You need to open it up and do the visual inspection and voltages checking. If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
More likely to have power supply problem, that will be the first place to check, look to see if it has any caps with leaking/bulging tops/seal, burnt spots, shorted transistors in the backlight inverter board, cold solder joints. Look at my DELL albums (BenQ made a lot of monitors for DELL). Be real careful when removing the front bezel, you can easily rip apart the cable. If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Look for bad caps. If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
these monitor have bad caps issues and also are known for bad solder joints after resoldering and checking the cap if problem is still there the there are 4 transistors ckeck the solder to these real close.C5707 if need to replace these thy cost about 1.49 each these are what turn off the power to the back light causing the monitor to sleep and not wake up.bluestarinternational.com sells partss for lcd repair. I repair 100s of these monitor most never needing any parts all most all ways its just solder joints cracked.if you need further info my company number is listed on this site as john's laptops there is a contact number there
You can try the following steps:
1. Disconnect all the cables from the monitor
2. Wait for 5 minutes and press the power button in the front once ( donnot connect the cables at this step)
3. Reconnect the power cable only to the monitor
4. Power on the monitor and check if you see a self test running on the screen
If the selftest feature is not running the monitor has gone bad. All dell monitor if purchased on a seprate order ,hold a 3 yr replacement warranty. If you have got the same with your dell computer, call Dell to check if its under warranty.
time for a replacement with the amount of data supllied, also see if the light indicator button comes on, if there is power, then check the video plug and card, do another video card and see if that corrects the problem.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Cause of power going
off:There is a bad 1000uF, 16V cap
on the power supply board.
Solution:Replace cap. Radio Shack sells a 1000uF, 35V
cap for $2.This will work.
Why did the cap go
bad?The cap is too close to a heat
sink and over heated.
What does this cap
do?This cap sends a signal to an IC
which keeps the monitor 'on' after the power switch is pushed.When the cap is weak, AC ripple voltage is
applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:
These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart
with a flat screw driver.
After removing the stand, you need to insert a flat screw
driver at the bottom of the screen where two slots are located. Then work the screw
driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit
board.
Unplug the monitor cords from the driver board and remove
the screen.
Unscrew the mounting screws from the power supply board and
remove.
You will need to pinch the plastic support in the middle of
the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be
on the side of the cap. It will be bulged up on the top. You will see burn
marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of
the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the
heat sink as possible.
Normal
0
false
false
false
font-size:10.0pt;
Why did the cap go
What does this cap
board.
the screen.
remove.
Cap Replacement:
