SOURCE: clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
SOURCE: Front panel connections for Hotpoint WMA 46 washer
red/red = x2 black/blue = x11 black/black = x9, hope this fixes for you
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
SOURCE: Need connector block connections for horn wire,relay to button.
The horn switch provides a ground. If you have no voltage at the horn wire, inside the steering whel, I would suspect a bad spiral cable, or clockspring under the steering wheel.
SOURCE: Panasonic SA-PT460 without speakers,where do i get the connectors
We have EXACTLY the same problem and have found out from Panasonic that the connectors are unavailable. We are at present trying female connectors covered with heat shrink tubing. Seems to work but having the right ones would be a lot better.
