Question about Samsung Televison & Video
SAMSUNG TV UN65JU6700F RED LIGHT BLINKS 6 TIMES . TV DOES NOT COME ON AT ALL
Posted by AAROM L. BILLICK on
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
My Samsung 50 inch had the same problem. Searched the web and it was the only capacitor in the power board that needed change, voltage was 382 volts. Replaced the old 100 uf 450 volts capacitors with two capacitors 150 uf 400 volts and 220 uf 400 volts in parallel and measured the high voltage at 390 and the TV was back to normal. (Make sure the capacitors from an old TV and computer power supply is rated for at least 400 volts.
Posted on Oct 31, 2017
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Posted on Jun 22, 2008
Anonymous
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
ABRsvcs
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
kodi319
SOURCE: red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Posted on Dec 03, 2008
Chi Chu
  • 8457 Answers
SOURCE: my plasma philips tv dosent turn on and red light blinks 6 times
Power supply board have dead capacitors.U know how to solder?Replaced these capacitors that bulge up,puff up or burst open.Should get ur power back.Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
Posted on Feb 06, 2010
SAMSUNG TV UN65JU6700F RED LIGHT BLINKS 6 TIMES SET DOES NOT COME ON
High voltage circuit is bad and usually is the capacitor that needs to be changed. Open up the back of the TV, and there are three boards. The one with the power cord is the power board/circuit. Change the capacitor - a 450 volt 100 uf. It should be at least 300 uf if not 400 uf at around 400 to 450 volts.. Samsung was trying to save money.
Oct 27, 2017 | Samsung Televison & Video
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
I have the Samsung model: LN46E550F6FXZA, I can hear it power on, the red light on the front blinks 5 times then goes off. There is no sound or picture.
You will need to have it repaired, looks like the inverter board is broken. Google Samsung tv blinks 5 times, there's tons of threads.
Mar 09, 2015 | Samsung Televison & Video
Samsung s50hw-yb01 red lights blinks 6 times
Google the model number with "error codes" or 6 blinks or as last resort call Samsung customer service
All blink codes indicate something wrong in the set and are only general in nature--will not of course say replace this specific part.
Apr 09, 2012 | Televison & Video
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Lost all Power to TV
My TV did the same thing today. My red light blinks 6 times. Any help would be much appreciated!
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Nov 06, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Televison & Video Logo
Demonic-2011
Demonic-2011
