Question about Sony Office Equipment & Supplies
I have a VPL-HS20 model Sony Cineza Projector and I was preparing it for sale cleaning it and discovered my air filter that was caked in dust.
My question is,I air sprayed all the dust off it,is this good enough,or is there more,or do I replace it and if so where do I purchase this filter for my projector?
Posted by Michael Daury Jr on
2 Related Answers
BlackOnyx
BlackOnyx
  • 102 Answers
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Posted on Feb 06, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: HOW TO REPLACE FILTER "SONY PROJECTOR MODEL VPL-HS3"???
http://www.manualowl.com/m/Sony/VPLHS3/Manual/789?page=38
Posted on Apr 12, 2012
Testimonial: "Thank you very very much @SD Tech ... God bless !!!!"
Ive recently bought a second hand Sony Cineza VPL-HS2 projector and it doesnt have an AVG input in the back. It does have a S-Video input, a 'video' input and a couple of audio inputs,
I think you mean "VGA" not "AVG". You can use the VGA to S-Video adapter to connect the laptop to the projector however you may get better results using a VGA to A/V (component) adapter to feed video into the RCA video input connector.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Sony Cineza VPL HS2 Multimedia Projector
Temp/fan light is on when you plug in the projector.
Try getting a can of compressed air and cleaning the fans out
May 24, 2014 | Sony Cineza VPL HS2 Multimedia Projector
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
Jul 10, 2012 | Sony VPL-HS51A / VPL-HS60 Multimedia...
When the projector is turned on, the green light
Sir it seems air in out problem.Clean all air filter or open lamp cover and give air pressure using with air blower or vacuum cleaner
Feb 25, 2010 | Sony Cineza VPL HS2 Multimedia Projector
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Nov 29, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
VPL-HS20 shuts down in the middle of a movie
There is a heat sensor cutting down the power. The sensor is located on the upper side between lamp and fan and is monitoring the air temperatur. I don't know what is causing the sensor to switch - excessive heat or simply age or ... . Anyway un screwed this sensor and my problem disappeared.
Possibly a stronger fan would solve the problem too.
Jun 26, 2008 | Sony VPL-HS20 Multimedia Projector
VPL-HS20 issues...who's got the right answers!
I know this post is 3yrs old, but wanted to add a couple things. I have the VPL-HS20, you can take the filter out and blow it out with air can duster every so often. I bought a new one and they are over $30.00.. Also buy the correct bulb LMP-H180 3000hrs if you replace it. You can clean the front lens protector, Remove slide tab, hold top and bottom of lens cover assembly and give a firm 1/4 twist clockwise, then pull out. You can clean it with glass cleaner cloth.
May 04, 2008 | Sony VPL-HS20 Multimedia Projector
Blue "Haze" at top of screen
My VPL-HS51 just started doing the same thing. There's a lot of similar reports out there and they all end up at the same bottom line - the problem is due to a design defect in the 'prism block' (LCD panel) and the only option, other than to throw it away or sell it for parts, is to pay Sony about $2300.00 to fix it. Good luck!
Dec 18, 2007 | Sony Cineza VPL HS2 Multimedia Projector
54 people viewed this question
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
